Home > In Car Electronics (L322) > An experiment that may of worked
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Well for the last 6 weeks or so I have had to live with my stereo switching off and the screen freezing, I could not change into menu and get into any of the settings, nav, on board computer etc until it unfroze, either a few minutes after or longer.
So my fix ( I hope), yesterday I wanted to look at the nav disc, could I get that out of the machine......heck it took a while for it to spit it out, pressing the little eject button just wasn't having any of it, when it finally came out the disc has a small mark on it so I left it out and run without the sat nav.
Now after starting the FF it seems the stereo has stayed on, no cutting out, no freezing screen and Im able to get into every setting with out problems, only no sat nav!....the first time the FF started up the screen did have a different coloured screen ( blue and not showing on and off road nav) but has now gone back to the usual black screen.
Very strange as I thought the nav was completely separate!
Oh well happy days Thumbs Up
Any one else had that second screen and why does it do that?
 If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #229013 14th Dec 2013 12:13am
SteveMFr
Site Sponsor
The nav computer is freezing on you due to disc / read probs. Try a new disc or you'll need a new laser.
The different color screen is because the nav computer apparently did not boot with the rest of the sys when you first re-started. The default display in the head unit is the blue screen you saw. When the nav unit came back up it redefined th colors and options.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #229017 14th Dec 2013 12:30am
BMW mode maybe? Looks more like a P38 display? An earlier software version maybe?
Post #229020 14th Dec 2013 12:36am
Welshdragon
Thanks for the quick reply, my disc is a 2002 year so if I decide to get a new one which year will work with the driver ? or would it be better to get a new driver and more up dated disc ? I still use my old tom tom as thats has the more up dated maps!
The main thing is the stereo does not cut out, which is far more important than knowing where to go Laughing If it dont work.......burn it!
Post #229109 14th Dec 2013 3:14pm
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
I've had the same thing when both mk 3 and 4 sat navy's have decided not to work, if you remove the sat nav completely you will get the blue screen
Post #229110 14th Dec 2013 3:18pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I have it frequently
Blue screen and the freezing screen
And its all to do with water
Leave the hatch open and always use the aircon then it will dry out
And never take it into a carwash
Post #229225 15th Dec 2013 12:08am
