Home > Technical (L322) > Checking gearbox on used TD6
jaipal2004
Hi,
going to check out an L322 Vogue TD6 and wanted one that had already had a new box in - believe that's better than one that maybe has one on its way out?
Have been told the one I'm goig to see now has a recon box in but he cannot find the receipt. Is there any way in which I can check it's not the original one in visually? He said it still has the stickers on it etc but as I'm new to RR's would prefer your advice on here Smile
Is there a prescribed method for checking the gearbox is ok? Can you check the ATF for colour and smell (guess it should be unburnt and cherry red??) or am I not able to do that?
Thanks guys
Post #229533 16th Dec 2013 2:40pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Ask where it was reconditioned at and call them ask if they have a record.
Post #229541 16th Dec 2013 2:50pm
jaipal2004
Smile
I did think of that but unfortunately the work was paid for by previous owner to the current one and at some point the receipt has gone AWOL. It was sold from Blackburn and have looked at transmission places in the locality and there's quite a few.
Any other way of checking?
Post #229580 16th Dec 2013 4:40pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Crawl under it and look if it has a reconditioned by ...... Sticker on it.
Really without the receipt or memory of what garage did the work you're fishing.
If what the current owner is saying is true he should know roughly what mileage the gearbox was replaced at you could check the mot records for a mileage that matches as close to possible as what he said and you know probably what year it was refurbished. But it's an awful lot of work for something silly like losing a receipt.
Good luck. Bushy
2003 RR Vogue Monté Carlo Blue
Post #229598 16th Dec 2013 6:04pm
