Home > Technical (L322) > Horns - where are they
billcyn
United Kingdom 2008 Range Rover Vogue TDV8 Epsom Green
One of my horns is on the blink so checked the Manual (section 413-06) to see how to gain access. Removed the horn access panel as described (5 clips, 3 screws) but no sign of the horns! Am I missing something (other than the horns) or are there others panels to remove which are not detailed in the Manual?
Post #229622 16th Dec 2013 8:21pm
Maybe that's why it's not working? Smile
Post #229623 16th Dec 2013 8:24pm
wrong side of the range? ... - .- -.
Post #229625 16th Dec 2013 8:27pm
billcyn
Yes, guess the manual could describe LH drive model with horn above nearside rather than offside panel - anyone throw any more light on this?
Post #229626 16th Dec 2013 8:42pm
Mine sounds puny, but I can't remember wether it used to sound more "manly" before Got - 2017 SDV8 Autobiography in Loire Blue
Post #229639 16th Dec 2013 9:50pm
The horns are under the right hand wheel arch. According to the manual you have to: "remove 5 scrivets and 3 screws securing RH wheel arch extension to splash shield and bumper. Then remove front wheel arch extension."
Post #229641 16th Dec 2013 9:57pm
billcyn
Strange - this bit is missing from my Manual - "Then remove front wheel arch extension". Will have another go
at this when the weather improves. Many thanks for your suggestions.
Post #229645 16th Dec 2013 10:06pm
from the workshop manual,
Post #229650 16th Dec 2013 10:29pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
...I remember doing this to my 4.4 after I er ..... filled them with mud on Salisbury Plain Rolling with laughter Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #229655 16th Dec 2013 10:38pm
paneldamage
They are bolted to a bracket on the inside face of the bumper armature on the offside.... I think it's easier to go in from the top, if you can take the headlight out easily....
Post #229671 16th Dec 2013 11:19pm
billcyn
Finally had a go at removing the horns again as per Stan's diagram above only to find that access is totally blocked by the auxiliary radiator. Obviously the manual hasn't been updated since this extra radiator has been fitted. The only other access method seems to be by removal of O/S headlight unit (as suggested above) which I'll be doing when weather improves. Ah well, we live and learn!
Post #233432 7th Jan 2014 4:28pm
JAYBOY
Head light removal is an easy job. Thumbs Up
Even I can do that one Surprised 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #233433 7th Jan 2014 4:35pm
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
My horn is like a mouse squeaking, my SMART car has a better horn Laughing 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #233434 7th Jan 2014 4:47pm
you need to get one of these,
Post #233440 7th Jan 2014 5:10pm
billcyn
The elusive horn - the search continues.... This morning I removed grill and N/S headlamp unit but horn still not accessible - can't even see it with inspection camera but its there somewhere as I get a single tone beep when operated. Looks like front bumper removal to get at it. Does anyone know for certain that this particular model (2008 3.6TDV8 Vogue) did have twin tone horns as original spec, as I've been led to believe? Also is it a bumper removal job to get at and fit replacements?
Sorry to bang on about this but if anyone has a definitive answer, please put me out of my misery!!!
Post #233584 8th Jan 2014 3:17pm
