![]() | Home > Maintenance & Mods (L322) > Creak when parking RR? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I am guessing it is just the parking brake taking up the strain. My TD6 doesn't squeak, but you feel the drums coming on line so to speak. Try applying handbrake, go to Nuetral, take foot off brake in Neutral, let handbrake take the weight, then footbrake back on to go into Park. This is the "approved" method (awaits |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
^ I'm with you - brakes on first before engaging park . . .
There's a 'roll' moving into park as the pawl grabs - it's not a huge amount in the gearbox but as it gets to the driveline it is exaggerated. Nearly all automatic gearboxes do this. So either put it in park, foot off brake, let it 'roll' then handbrake to lock, or expect physics to occur |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Hmm, mine's never made a creaking sound though I just put my foot on the brake and press the start/stop button and the car puts it into park and applies the parking brake. I'm assuming it knows what it is doing. 4.4 TDV8 Vogue Baltic Blue MY11 |
Never knew any of that (knew nothing was wrong with the car. I just put it down to, as you say, physics. Will try your suggestions and report back).
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Another vote for a variation of the above method.
Top tip gents thanks. The first descibed method tried and works a treat. The noise has 'gone'.
i reckon its your old bones creaking Ryan.. |
Do you know Stan, was going to put that on my reply in light hearted jest... but it would not have been true! |
