![]() | Home > In Car Electronics (L322) > sat nav urgrade disc |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
when I've popped mine out before now I noticed it has the year on it. Perhaps yours may |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Yes you may change the country. But it defaults back to France, and for £3.99 i expected better |
zetjester Member Since: 01 Apr 2013 Location: Northamptonshire Posts: 48 ![]() ![]() ![]() |
I can only get the original LR discs to work in mine, and was told by an Indy DVD repair/recon company that the copies
DVD's break lasers? Er....<cough>
I have tried a few copies and only the original disc will read! |
Yep - slowest speed possible and good quality backup discs |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 ![]() ![]() ![]() |
Hi guys I'm new to this RR scene and was wondering will a newer map DVD work in my 2005 RR, also where is the best place to locate said item.
tobylo Member Since: 26 Jul 2012 Location: Dublin Posts: 52 ![]() ![]() ![]() |
@ Paul_H, i have 2 original discs, 2005 and 2007/2008 that i no longer need. Send me a PM and i'll send you on the details. They work in the Denso units, if you have a touch screen sat nag they will work. |
Sat nag !!! |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Surely these are from the same supplier as the RR puddle lights ![]() |
Here in Australia if you need a new disc you are screwed |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
It won't make any difference. If you still have CD navigation you won't find newer maps than 2003. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
pm sent David.. ... - .- -.
