Home > Maintenance & Mods (L322) > New LED sidelights
Page 2 of 4 <1234>
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
100% agree. Also interesting posted thread by Stan, I'll have to look into some upgraded fogs now Laughing Bushy
2003 RR Vogue Monté Carlo Blue
Post #229493 16th Dec 2013 11:16am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I like mine I did myself Wink
Post #229676 16th Dec 2013 11:35pm
Bushy513
Very bright Thumbs Up Bushy
Post #229684 16th Dec 2013 11:45pm
looks nice but what the FAK ?Wink All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #229719 17th Dec 2013 9:08am
Andy
Just ordered a pair. I've got LEDs in at the moment but they're starting to flicker after only a few weeks and have a blue appearance which I kinda liked to start off with.
Just hope these new ones are bright!
Post #229909 17th Dec 2013 11:23pm
Scottyav
Here's my secret Wink take lights out and remove glass cover measure the circles one is 110mm and one is 120mm I think, the top one is coned so slide the led ring over with a small amount glue/silicone on inside then push on tight,now the bottom one put a line of sealant around bottom circle then stick the bottom led on on leave to dry then drill hole in plastic back feed the wires through to a connector and join to side light or aux ign if you want permanently on, the rings are about £5 a pair on flea bay then just a little sparky knowledge and presto saved a fortune and looks the dogs Smile
Post #230002 18th Dec 2013 1:54pm
Googsy
I used 3m tape to fix mine around light lens no need to wait for drying then Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #230007 18th Dec 2013 2:43pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hey Scotty
Any clues as to where you bought your led strips from. Did you have to cut them or where they the correct size already?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #230074 18th Dec 2013 10:26pm
Bushy513
Also quite interested in putting some rings around if it's that easy. Bushy
Post #230116 19th Dec 2013 11:29am
Googsy
Easy enough hardest part is getting your oven timing and temp right. I did mine for 8 mins at 130 fan assisted and made it easy to do. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #230127 19th Dec 2013 11:43am
Scottyav
The strips were off eBay they were 12 led but I cut three off now and it looks better, what do you need the oven for? No need to use it to do this mod oh I see yours is the sealed unit not sure on that model as mine is glass removal Wink
Post #230378 20th Dec 2013 11:09am
comports
Can you give us a link to where you got them. I can find loads of light strips but normally 5m in length. Don't think I'll need that much for the lights Smile Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #230670 21st Dec 2013 5:13pm
td6vogue
Got hold of sum leds today
Silly question but how on earth do you get your hand into the headlight to change it?
I have the 06-09 headlight
Post #230696 21st Dec 2013 7:47pm
pld118
Hi, do you mean you bought an LED sidelight bulb to replace the halogen bulb and you want to swap them?
If so, have you got an owner's handbook pages 264, 265 & 269 show how to do it?
Post #230698 21st Dec 2013 7:52pm
td6vogue
my owners hand book is for the original headlights
i have fitted the 06-09 as stated
Post #230701 21st Dec 2013 8:08pm
Page 2 of 4 <1234>
