![]() | Home > Technical (L322) > Heated driver's seat |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
common problem, have a look here,
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 ![]() ![]() ![]() |
Thanks Stan, just had a look at that but there's a load of info! I've had it tested and I know it's the element that's faulty, so is there anywhere I can get one that's not going to cost me an arm and a leg? |
Hi Squirrel
Hi Googsy,
Depends how big your bum is I suppose |
It's not big enough to require thermals costing in excess of £2000. I hope. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6375 ![]() ![]() ![]() |
There's an LTB about the steering wheel issue. Typically a motor going Pete Tong.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Hi my 03 drivers seat has got hot on the left side and heated close to the top and seems like it's burning hot can you unplug the base swab so the back still works or can you join the unplugged end to make the rest of the seat heat except on one side? _____________________________________________________
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
You can run a seat with less than the normal number of elements but, as you say, if you unplug an element you need to then close the circuit as all the elements on the pre facelift RR (<2005) are in series. If one goes open circuit none of the elements on that seat will work.
On the base swab where are the connectors to go to the three elements to disconnect I've lifted the side up a bit to see the burn does the seat have to come out? _____________________________________________________
The seat base element connectors are under the seat base, you don't have to remove the seat to get to them.
Cut the black and grey wire and joined them up but now the dash light stays on five seconds then goes off now ? The left side has burnt the swab so tried to bypass that side any ideas thanks. _____________________________________________________
If the light goes out after 5 seconds then it sounds like you have an open circuit, the same error I was getting.
Tried to get to the three with half the cover folded back but can't feel any are they under the foam or under the cover top even tried from rear back but no joy |
