Home > Technical (L322) > 2010 MY Dual View Option or Standard
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
What are the differences between my 2009 59 5.0 S/C AB, what i would call 2010 MY and the 2010 MY that is referenced in the original LR brochure please?
I have a price list, downloaded from LR website that has the date 2010 MY Feb 2010 on the top heading which shows that it was standard on my model and then an original brochure from the LR website which says 10/1 in the bottom left of the front cover and this says it was a cost option on all cars.
I also have a printed (bought off eBay) 2010 brochure which just says 2010 in the bottom left corner of the cover but that doesnt show the options, referring me to the price list which i downloaded and is referred to above.
I havent come across this option in my car hence the question, I wanted to understand if its there before I look again, incase I havent went into the correct menu or something?
I saw a unit with Dual View on eBay so asked the seller about retrofit to a 2009 59 and he said it can only be fitted in a 2010, more confusion?
Thanks and sorry if this is a bit of a dumb question. Embarassed
Carl
Post #230133 19th Dec 2013 12:06pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I had a 59 plate Autobiography 5.0 and the dual view was standard.
Ebay seller probably confused by model years - 59 plate was 2010MY Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #230144 19th Dec 2013 12:49pm
carlos50
Ah, so perhaps its just me then Confused
Will look again, thank you for the reply.
Post #230145 19th Dec 2013 12:51pm
redshovel
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
Only price list I have is the April 2010 price list and it was std on Vogue SE and above
https://www.dropbox.com/s/gz5c33og77u74sx/...20list.pdf
Post #230146 19th Dec 2013 12:52pm
Carl,
Are you certain you are trying it right?
The dual view button has to be toggled with the TV and sat nav on for example then lean across to the passenger side to see it working, should be there. Discovery 4 HSE
1993 90 Tdi
Post #230156 19th Dec 2013 1:15pm
And as an FYI, the '753' hack still works on the 2010MY if you want to watch TV as well Discovery 4 HSE
1993 90 Tdi
Post #230158 19th Dec 2013 1:16pm
carlos50
Is there a particular screen i have to be in to get the Dual View? For example, Nav / Map will let the passenger watch TV but radio / audio (USB etc) screen wont allow it?
Post #230159 19th Dec 2013 1:16pm
carlos50
Im probably not doing it right, will look again later.
What hack, do you mean TV on all the time?
Post #230162 19th Dec 2013 1:17pm
carlos50
Its ok found your post on it, not worth having to do it every time i start her up.
Post #230170 19th Dec 2013 1:30pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Mine was first registered in July 2010 and is a MY11 but although Autobiography spec no dual view. Dual View was not standard in some markets. There's a dedicated Dual View button on the side of the nav screen (the button shows two screens) on the cars fitted with it.
Post #230178 19th Dec 2013 2:24pm
carlos50
Ok so i have the Audio button with 2 screens on it, numbered 1 and 2 but how the f**k do i get it onto dual screen Laughing
I tried putting it on the map screen then pressing audio and it just turns me to the radio stations so i tried leaving it on that and pressing audio again but nothing, what is the process for turning this on please?
I'm such a thicko with this stuff and the manual just says press the button, did that, doesn't do anything.
Post #230230 19th Dec 2013 6:35pm
CSK
Just guessing here but I think you should put the TV or DVD on first, then push the Dual View button.
Post #230245 19th Dec 2013 7:19pm
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Dual view works whenever you engage a gear and let the handbrake off whilst in TV or DVD mode. Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #230313 20th Dec 2013 12:21am
5.0
^ Correct Very Happy
Post #230347 20th Dec 2013 8:20am
carlos50
Thanks everyone, will try it again today, was not in TV mode and also was in P so no wonder it wasn't making any difference.
I assume DVD mode is only for those with RSE, which i don't have?
Post #230364 20th Dec 2013 9:47am
