Home > Technical (L322) > Big Engine Problem
Page 5 of 5 <12345
Sorry if this is basic... But... You checked continuity of feed and pulse, but did you check if they are shorted? Previously..
Post #230629 21st Dec 2013 12:05pm
johnboyairey
Quote:
INJECTOR LOOM
With the loom unplugged on number 1 injector I tested the continuity of the feed wire and the Pulse signal wire back to their points of origin, all good here.
yes, my posts refer to it shorting to earth ie in contact with earth, like its beem squashed under a screw or something, i just wanted this to be known, before you go spending money on a part etc. from my amateur detective work here, i see you have this problem since PCV overhaul, and now you have an ECU fault! possible, and no doubt if so, was caused by something? maybe a direct short. (remedy first before spending!) test both wires to earth and wobble loom in affeced areas. if you are sure of this, no need to 'piece out' loom with temp wires.
and lastly, it runs ok on 7 cylinders, when injector1 disconnected? but still smokes a lot? i cant see you unsmoking it with a new ecu. but that's my hunch. car will tick over ok on 7, just feel sluggish on revving, and no need to revv it! did you remove inlet manifold???its possible its signalling the ecu to shut down one or more plugs. -this is a guess. i remember older bmw engines could do this. (v12 could run on 6 etc) maybe check over at friendly 7 series forums with m62 and m62tu44 engined cars for similar maladies. your lambas are getting beaten up with this smoke, and maybe trying to save you. keep posting. merry xmas!
Post #230638 21st Dec 2013 12:47pm
FTS999
England 2004 Range Rover Vogue 4.4 V8 Java Black
The PCV was changed after this problem started. I had and idea it was either that or the MAF. But neither made any difference. After checking all the hoses and connections, that was my Unmetered air theory out the window.
So we moved onto spark, coils and fuel
With reference to the smoke, If I disconnect number 1 injector and start it up, within a few minuets the smoke has almost gone with very little smell of it running rich.
If I reconnect the injector back up, then all hell lets loose. It starts missing, floods the cylinder and kills the spark, which passes through the cats and burns up.
We think the blackening of the other plugs is down to the system compensating, as the 02 sensor will have detected high levels of oxygen in the mix and requested the ecu to apply more fuel into the system.
I will try and carry out your earth logic tomorrow along with some temp wires running to the plug, Thanks very much
Just hope I'm right.
Post #230665 21st Dec 2013 3:48pm
johnboyairey
that post makes it all sound much clearer. it would indeed sound like the permanent open injector is at fault from a stuck pulse etc. have you checked with a dismantler for a second hand ecm?
Post #230700 21st Dec 2013 8:08pm
FTS999
I can get one for £200 but they need coding to the BCM something to do with the immobiliser.
I have found a company called Autotek in Bournemouth than can test and if possible repair my ECU.
If it can't be repaired then I will ask if they can transfer my info onto a secondhand unit,
Post #230713 21st Dec 2013 8:45pm
johnboyairey
in that case, don't lock your car without it in the vehicle, as mentioned earlier!
this sounds an odd fault to me, but then again, its a range rover!
Post #230864 22nd Dec 2013 7:39pm
JAYBOY
FTS999
How did you get on with the car. Question 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #233283 6th Jan 2014 10:08pm
Yes, would be very interested in an update... Thumbs Up Previously..
Post #233287 6th Jan 2014 10:47pm
FTS999
Hi Guys,
Due to the christmas break I had to wait until the new year before I could send the ECU away.
I had a call from Autotek yesterday. They have tested the ECU and found the fuel injection element had been overloaded.
So I have paid £415 of my hard earned cash for them to refurbish it for me.
Should be back with me this week
Post #233483 7th Jan 2014 9:19pm
FTS999
Hi guys just to let you know I got my ECU back now sorted works like a dream.
Thanks for all your help and advice it's been brilliant to work with people like you. I don't think I have ever had 5 pages of messages on a forum .
Thanks
Post #234772 14th Jan 2014 1:29pm
Good news.... Thumbs Up
What about the low compression? Have you tried testing it again? Previously..
Post #234779 14th Jan 2014 1:39pm
FTS999
Not as yet, but I will do them all again just to make sure.
Post #234860 14th Jan 2014 7:40pm
JAYBOY
Great news fella. You can now get back to enjoying it Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #234867 14th Jan 2014 7:52pm
Page 5 of 5 <12345
