![]() | Home > Maintenance & Mods (L322) > Rear window seal corrosion |
RXWRR Member Since: 30 Jul 2013 Location: Staffordshire Posts: 60 ![]() ![]() ![]() |
Mine were replaced by the MD under the corrosion warrenty. Better to be irresponsible and right, than to be responsible and wrong.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
I had mine replaced before I took delivery by the dealer. I have yet to see a 2010MY car that doesn't have this corrosion, very shoddy. Discovery 4 HSE
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
I had mine replaced under warranty a couple of months ago. No hassle from the dealer. Current MY2020
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
Same here - had this on my MY11 car and had it replaced by the dealer under warranty. no fuss or questions, so clearly a known problem MY11 Vogue 4.4 TDV8 - "African Queen" |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 745 ![]() ![]() ![]() |
Mines the same, looks horrible, I will expect it to be replaced when it goes in for its pre warranty expiry inspection. 2021 P400 Silicon Silver AB
uphilldowndale Member Since: 19 Aug 2013 Location: Chester Posts: 20 ![]() ![]() ![]() |
Thanks all.
From a Series 2 (do you mean a Land Rover, not a Discovery or Range Rover?) to a 10MY is a massive leap... Discovery 4 HSE
Yep - 1961 Series 2 Landrover - but only use it locally.
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 ![]() ![]() ![]() |
Mine have gone too, distorted and pulling away from glass. Mine is going tomorrow to have upper lid replaced due to rust on the entire seam and pointed out the trim. As they have to remove the rear screen, were happy to replace seals during this process. |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Mine have this too, what's the part no for them please? |
Van Diesel Member Since: 27 Oct 2013 Location: Norfolk Posts: 183 ![]() ![]() ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
The anti-corrosion warranty is 6 years, so it should be covered. I got my '08 done earlier this year. Got - 2017 SDV8 Autobiography in Loire Blue
Cheers Alan, will get it in and get them to look at bubbling on top of lower tailgate at same time. |
Just popped outside to get a couple of pics to verify if this is what others are getting. Looks like thee is a load of grit inside the n/s one where it has split?
