Home > Technical (L322) > Fuel pumps!!!
Page 2 of 3 <123>
adigorn
the in tank unit death in 12year old car wouldn be surprising
especially well documented on 322s
so it is something you should really consider being aware owner Whistle
Post #230884 22nd Dec 2013 9:04pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Mate I researched all the common failures on the 322 before biting the bullet. This being one of them.
But one after the other non stop gets a bit much. So it's nothing to do with being an unaware owner.
Post #230891 22nd Dec 2013 9:19pm
adigorn
Wink
i get it
im on the other side or barricade so i love that they are what they are
Post #230893 22nd Dec 2013 9:22pm
paul271
The thing that winds me up the most is that i absolutely love the thing!!
Was driving a brand new Ewok the other day and it just didn't compare! I dare say once i've had my tantrum and its fixed i'll be fine!!
Post #230931 22nd Dec 2013 10:54pm
adigorn
ewok Rolling with laughter
you are not allowed to compare freelander to RR Mr. Green
Post #230934 22nd Dec 2013 11:04pm
paul271
I was gonna recover it to my local Indy but i decided that since it drives intermittently i've dumped it at my Grandfather's where i can do the pump myself and hopefully save a few quid!!
Does anyone have any suggestions on where to get just the pump unit from? I can only seem to find the entire in tank pump assembly.
Post #230940 23rd Dec 2013 3:01am
You need to make sure you are changing the right pump or else it could be costly
Post #230958 23rd Dec 2013 10:19am
paul271
I know. I'll have to get it to cut out so I can get underneath and have a listen. The fault codes only tell me it's a fault on the low pressure system. I was assured that if I get the INJ SYS FAIL message then it's the in tank pump?
Post #230961 23rd Dec 2013 10:56am
adigorn
you are right its intank Thumbs Up
Post #231090 23rd Dec 2013 7:42pm
paul271
Guys I've hunted high & low to try and find a part number or supplier for just the pump inside the whole sender assembly.
I saw somewhere that there was a BMW one available? The only one I can find is for the V8 petrol though.
Post #231158 24th Dec 2013 12:13am
Are you sure it's the pump in the tank that's at fault?
The most common one to cause problems is the one at the rear wheel!!!
Post #231175 24th Dec 2013 1:19am
adigorn
Can you explain how could it be the one behind the wheel
(even if its lets say common one)
If the car is displaying INJ SYS FAULT message ???
Post #231178 24th Dec 2013 1:26am
paul271
Sorry guys i should have said, the one behind the wheel was changed a few weeks back.
Post #231191 24th Dec 2013 3:43am
paul271
Found an aftermarket pump at a good. I'll copy & Paste across the part no and site once I'm back on laptop.
Post #231193 24th Dec 2013 5:16am
paul271
So, it was booked in to my local Indy today for brake pipes and the pump didn't arrive till today too. Got it recovered over to the garage yesterday.
They fitted the pump and still weren't happy with the pressure. Changed the filter too and hey presto! There is some gunk in the bottom of fuel tank so it'll be getting dropped in the near future and cleaned out.
Seems a lot smoother now.
Post #232075 31st Dec 2013 12:28am
Page 2 of 3 <123>
