![]() | Home > Technical (L322) > New Purchase - Venture Cam Not working |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Best remove other cameras that will be stored in your settings.. Go to the v.c. Screen, it will be obvious what to do. Then reinstall new one.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
How long did you leave it to charge? It can take quite a while, it's not the most up to date bit of technology in the RR.
Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267 ![]() ![]() ![]() |
Removed the other cam stored.. Cannot install new one as nothing recognised..
I'm sure you are doing this already but the venture cam will only pair when its in the dock and charging . 2008 MY Supercharged
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Mine has had water at the holder at sometime and wont work also think the board in the charging socket is us on mine.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Note: The green charging halo only comes on for a short while when vehicle started. Previous cars:
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
The touch screen also shows V Cam charging [or not!] |
Update.. Been for a very long drive and still nothing from the V Cam...
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
You may have a slightly warped holder so the two charging discs on the cam aren't connecting to the pins, this happens with my docking station and I've had to put a strip of plastic into the side of the holder once the cam is stuck in the holder. Try sticking the cam in the dock and wiggling around, whilst in the vcam screen and with the engine running, you should get a battery charging icon come up and vcam charging message.
Any chance you could pop it in another fatties holder to test it? Previously..
That would be good an option - To check if it is the new Cam or the FF wiring..
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
Sorry to hijack your thread but my new to me full fat displays a message on touchscreen "venture cam charged" where does it live ? I haven't found it yet lol. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35703 ![]() ![]() |
glove compartment next to the cd changer... ... - .- -.
Thanks Stan will check it out. |
