![]() | Home > In Car Electronics (L322) > Alpine EZI-DAB |
| jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308
I do have a brand new, boxed, one of these in my garage plus the External DAB antenna if anybody wants to make me a realistic offer.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
An LR DAB unit on a 2007 car? Where did you get that from? Got - 2017 SDV8 Autobiography in Loire Blue
| ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77
Other things keep stopping me!
Hope everyone is having a nice Christmas |
I started off with this as a base -http://www.brodit.com/product.html?id=854085&pn=prod&brand=Land Rover&model=Range Rover&year=2007. This will fit on either side of the nav screen.
Thanks for your prompt reply!
Just be careful where you mount the DAB antenna. I fitted mine on the top left corner of the windscreen and all was well, but I've recently added a Blackvue camera, which all be kills the DAB signal, so I'm probably going to have to move it. Got - 2017 SDV8 Autobiography in Loire Blue
That's interesting. I have a camera mounted by the rear view mirror also. I didn't think a camera would stop DAb from working correcty! You are either at Le Mans or waiting for Le Mans
If its a Blackvue, then It almost certainly will. Do a Google search and you'll see it's a well documented problem.
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
hi, interested, but a question, if you have this via a line in, does the satnav voice still override? I have a 2002 with vogue radio, it has a Bluetooth 9200i parrot, it works excellent, but when I have my ipod on Bluetooth, the voice is lost, it doesn't mute. which I don't actually mind, as I can listen to something interesting on radio 4 podcast, and not get told to turn left. -I do still get the display arrow etc and info, to read...
Because I use mine via the AUX input on the RSE panel, the Sat Nav voice does indeed override whatever is playing through it and I guess if the FM option was used that would also work. Got - 2017 SDV8 Autobiography in Loire Blue
Yes FM would work the same way, also the telephone mute works as normal You are either at Le Mans or waiting for Le Mans
I installed mine yesterday and put the aerial at the top left of the windscreen. So far I can say that the camera I have makes no difference to the DAB signal. I have one of these with GPS http://www.ipixi.com/v300hd/# You are either at Le Mans or waiting for Le Mans RSW MKIII V2 All Comms in Central Scotland |
Sounds like yours is shielded better than my Blackvue then. Got - 2017 SDV8 Autobiography in Loire Blue
