![]() | Home > Maintenance & Mods (L322) > egr |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Certainly is. |
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 ![]() ![]() ![]() |
. thats correct |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
How are you going to blank it ? .
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Left the egr in place on mine, although i did remove it to clean all the carbon |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
With the blanking kit I bought |
Wish I knew that... ![]() ![]() ![]() |
On the plus side though, at least you wont have to clean all the |
Thought you may have found a shiny metal disc of suitable size to poke in the end of the exhaust gas inlet |
The valve should be closed when there is no vacuum Joe90 so yours must have been stuck open. Not surprising though with the amount of carbon you find in them. I gained around 2-3 mpg after disconnecting it. Also got peace of mind that the engine isnt breathing in all the carbon |
How long does if take to do ? Also did you use fire gum on the blank off bit. Can I use silicone ? |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
less than an hour including tea and a bacon roll..............its a very straightforward mod happy to help if you want a trip down south |
about 20/30 minutes done unrushed,,i used gum gum as that is well known for its reliability when it comes to blocking out exhaust fumes.. |
