![]() | Home > Technical (L322) > FBH |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Sorry if this has already been done but i can't find anything.
Thanks Mark
All sorted.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
with a MY11, you wont be getting into a "warm" cabin. With only a 17 minute cycle time (come on LR - how much extra would the full 30 minutes take from a proper battery to adequately warm the cabin....), it will be cool at best on really cold mornings. |
Checked this morning and guess what.
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
Battery issues on the Range Rover are legendary why JLR can't address this problem once and for all god only knows, surely not that difficult or expensive to have a secondary battery fitted to power ancillary things like FBH to give some decent cabin heat times leaving the main battery for start ups |
I'm right pi55ed off as you can imagine.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
Has your vehicle had the FBH update and the upgraded battery, mine was done under the factory recall |
^ The FBH update was a reduced cycle time and the battery was a gel replacement...true it all helped but it's more of a patch than a real fix as Ramble says in really cold weather the cabin is still a cold place to be in until the engine heat kicks in |
No my car has the original battery. The FBH cycle time says 30 mins 2020 Porsche Panamera Turbo Hybrid (V FAST)
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
If its not working then chances are its bust......
Updates and battery replacement were part of a recall and should have been done...phone Lookers tomorrow Jay |
I will be on the phone first thing.
what I do sometimes to make up for the poor battery is......
