![]() | Home > Technical (L322) > engine seized ? |
Ragerover Member Since: 02 Feb 2011 Location: Newcastle Posts: 220 ![]() ![]() ![]() |
Good chance you've just bust an inter cooler hose
Petr Member Since: 31 Dec 2013 Location: Middlesex Posts: 7 ![]() ![]() |
Hi ragerover
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
best bet is to get the oil drained from the sumps and check for any metal in the oil, this will give an idea if any bearing damage has occurred with the engine being low on oil.
Hi thanks Andy
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
There's been another thread very recently about a TDV8 with similar sounding problem to yours. As i remember the other car had possibly injested it's turbo, which also sucks all the oil out of the engine. |
This one ?
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3804 ![]() ![]() |
I also personally know of examples involving remapped engines & increased fuelling & upped boost pressures resulting in warped manifolds and bearing failure = engine totally goosed. |
