![]() | Home > Technical (L322) > Non starter 4.4 v8 |
Saltyfish Member Since: 19 Jun 2012 Location: Yate/Bristol Posts: 22 ![]() ![]() ![]() |
Went to start my 4.4v8 early this morning after a day of it being stood up. Turned over but would not start (it was fine 24hrs ago). I have checked fuel pump and that is fine i also checked fuel is being delivered at fuel rail and thats fine.
Yes have tried that, have also now checked fuses in E-box.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
the battery has to be 100% for all the ecu's to function....i'd test that first.. ... - .- -.
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
Apparently the ignition switch can fail, this similar problem to yours ended up being a broken connection in the fuse box.
Battery is at 100% charge. 04 Vogue 4.4LPG.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Any unusual messages coming up as I had a similar issue a year or so ago, but it threw up a ' CODE ----' on the display, Turned out to be a faulty instrument cluster |
There appears to be no power to the dash apart from the mileage display. I'm now thinking a fuseible link (no 2) may have blown as this appears to power everthing that has stopped working. 04 Vogue 4.4LPG.
UPDATE.
UPDATE.
did the garage diagnose and repair? |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
The AA diagnosed and i repaired.
