![]() | Home > Maintenance & Mods (L322) > Steering Wheel Spokes |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Deleted |
You need a long narrow screwdriver. Dont jam it into holes as you could cause damage. I had same issue as you but have done it so many times now I could do it blindfolded. You need to apply only moderate pressure working the scewdriver at different angles in a circular motion. You are trying to compress a spring on each side and jamming it in a pushing hard means you aint at right angle in order to realease airbag. Trust me be patient and try different angles applying moderate pressure and you will definetly release airbag. Hope that helps. Present :2008 TDV8 HSE
I now have a nice new (not) shiny steering wheel in place. Very nice. HOWEVER…..
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7934 ![]() ![]() ![]() |
No modification needed for me just fitted straight on. Present :2008 TDV8 HSE
Well it's a 50/50 shot. Googsy! |
