![]() | Home > Maintenance & Mods (L322) > Brembo calliper cleaning |
Funnily enough they are not black but a dark grey. I took wheel off and used a tooth brush combined with a dedicated wheel cleaner that brought them back to newish condition. If your after a shiney black finish then you will need to respray and stick on new brembo decal. Present :2008 TDV8 HSE
Van Diesel Member Since: 27 Oct 2013 Location: Norfolk Posts: 183 ![]() ![]() ![]() |
Nice work Googsy, so maybe my callipers are not as bad as I thought as they are a dull-ish grey. Thought they were black originally. Is the original Brembo logo painted or vinyl?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
You'll probably find she's already used yours to clean the toilet! |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Or..... Check out these bad boys.... |
Do they fit Range rover? Present :2008 TDV8 HSE
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Gloss black ones are on the SC, Matt Grey ones on the TDV8 and the Brembo logo is kind of etched into the alloy ![]() |
Our SC has the matt grey front Brembos ? |
I think they are meant to be black but some car's got what was in the parts box on the production line . 2008 MY Supercharged
same as Ryan ,mine are matt grey as well......
Later cars got a mix and match I think stan... All pre 07 interior facelift cars got gloss black ones then it just got pot luck I think... |
Im also pretty sure the replacements from JLR are either only available in Grey now or Black ones are twice the price! |
My '56 plate SC had grey Got - 2017 SDV8 Autobiography in Loire Blue
knowing LR ,your theory sounds about right craig ..
