Home > Maintenance & Mods (L322) > Alternator goosed red battery light now on.
Googsy
Haven't used car in a couple of days went to start car this morning and she hesitantly started. As I wasn't going anywhere and was just moving car I thought I would plug in my solar trickle charger. I had noticed over the past few months a whooshing noise at low speeds and after posting here someone reckoned it was alternator. Battery is 2 months old . On trying to start some 5 hours later nothing just that clicking noise Big Cry I jump started car tonight from my neighbours Disco3 and we had to run it with cables on for about 5 mins before I had enough juice to start engine. Once started everything seemed fine so disconnected leads and closed bonnet . Left car running but then it just cut out after about 2 mins. So as it's dark and I'm minding junior will try another jump start in the morning . Hopefully the extended warranty company will agree to pay if it is (alternator is specifically covered). My car is March 2008 and on 79k miles so looks like it might fall into the growing list of 2007 TDV8 alternator failures that of course being the case if it is in fact the alternator but I have that feeling it is Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #232727 3rd Jan 2014 9:37pm
JAYBOY
Good luck with the warranty mate Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #232728 3rd Jan 2014 9:39pm
Yep Banging Head sounds like the alternator that Conor. The fact that it ran for a bit then Cut out is a bit of a tell tale sign.
If you can get it running again use the 753 code and check the voltage that you are getting, after initial drop it should read 14ish There is nothing that can't be fixed with a hammer😜😜
Post #232734 3rd Jan 2014 10:05pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Surely if it's fully charged it should read 12/12.5v? 14v on a charging cycle, then 13.5 etc .... it is essentially a 12v battery! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #232741 3rd Jan 2014 10:27pm
Will tend to read high after starting around 14v as the charge is replaced then drop slightly after the charging is complete afaik, with a non running voltage of 12.5ish. Yep that's what I meant.
If it's not showing 14 ish when running the alternator is cooked....... There is nothing that can't be fixed with a hammer😜😜
Post #232742 3rd Jan 2014 10:36pm
Googsy
Okay update. Charged battery car started with ease connected iid tool for live voltage values. Values whilst driving were between 12.8 up to 14 with an average of 13.5 so this makes me think alternator is fine. It could be that I had quite a few short runs and left car for 2 days without driving. Drove car during test for about 40 miles with no issues so was thinking if it was alternator car would have died at some stage during test. Maybe one of those range rover weird electrical occurrences that seem to plague us ....... Thoughts and input always welcome.
Thanks
Conor Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #232820 4th Jan 2014 3:34pm
JAYBOY
That was lucky Conor Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #232824 4th Jan 2014 3:39pm
Funnily enuf mine flattened it self over christmas, was down to a interior light on.......and seems fine now, but would have not been dead flat if it hadnt been only run for short spells over xmas.
I would monitor the voltages over the next few days. But it does sound like you may be ok, as you know lots of short journeys will flatten it especially if you have used the fbh. There is nothing that can't be fixed with a hammer😜😜
Post #232869 4th Jan 2014 7:28pm
Googsy
Yes I had also left fbh on timer and didnt drive car so makes sense. Like you though I wont be happy until its replaced . Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #232871 4th Jan 2014 7:43pm
FBH for a few cycles will kill it - hope thats all it was Thumbs Up
Post #232872 4th Jan 2014 7:46pm
Googsy
So battery light has come on managed to make it home but car running. Still need to get sorted should I call warranty company or ask a mechanic to check? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #233231 6th Jan 2014 6:30pm
DMRR
Which one - they turn off after 15mins? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #233264 6th Jan 2014 9:18pm
One of the reading lights in the rear of the car, not the main interior lights.
I also used it to fill a couple of air matresses via the rear socket Whistle There is nothing that can't be fixed with a hammer😜😜
Post #233267 6th Jan 2014 9:25pm
DMRR
Reading lights go off after 16 minutes.....
It's very hard to leave the interior lights on in these things Wink Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #233269 6th Jan 2014 9:30pm
Combo of all the general battery abuse that it has had over the past few weeks fbh, air bed filling, boot open, all seems ok at the moment, it is charging fine and starting with gusto! At the moment..... There is nothing that can't be fixed with a hammer😜😜
Post #233270 6th Jan 2014 9:40pm
