Home > Maintenance & Mods (L322) > LED Indicator Upgrade For Early Cars
Page 3 of 5 <12345>
Are they much brighter Stan?
Post #232843 4th Jan 2014 6:17pm
yes they are and the quick sharp on/off helps as well...
Post #232844 4th Jan 2014 6:20pm
Do you have a link for them please pal...
Post #232848 4th Jan 2014 6:26pm
http://www.ebay.co.uk/itm/50w-AMBER-CANBUS...19e6c48fdc
Post #232851 4th Jan 2014 6:33pm
mjdronfield
Ah - good shout on the lumens - nearly ordered them. Poss a bit bright then. Don't want drivers behind coming after me with a blunt instrument !
From Stans link, it looks like 30w clear are the equiv of 50w with amber.
Will do another search then..........
Just ordered bulbs for the side indicators in the front wing, so will have to do the others now ;
http://www.ebay.co.uk/itm/2x-ERROR-FREE-CA...410295557? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #232859 4th Jan 2014 6:39pm
Thank you Stan Thumbs Up
Post #232860 4th Jan 2014 6:42pm
pld118
Craig, the front & rear LED indicators bulbs I've used are brighter. The difference on the video I took at night of both old and new side by side on the rear shows that the new is brighter (subtly though) & gives a more even performance.
Trying to find the video...
Post #232881 4th Jan 2014 8:16pm
mjdronfield
I believe I have found a bulb suitable. A 20w Cree unit using 4 x 5w Crees.
The seller on the bay does not state a brightness, but I found a seller in Germany who says 500 lumens.
http://www.ebay.co.uk/itm/P21W-382-BA15s-X...3a7e4437ba
Unless anyone has any doubts, I'll order them later. They are £30 for 2....
I've also just ordered the below for the reversing lights. A bit cheaper for 2, so can see how they go.....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...OC:GB:3160 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #232925 5th Jan 2014 7:03am
pld118
Mark,
If they are a reputable seller, you could perhaps message them before ordering and explain the year, make and model of car you intend to fit them to and you can ask them if they are not compatible will they refund you, provided you return the bulbs in the condition they were delivered. 3 sellers I've used have all said 'no problem' to such a request and the only bulb I had some issue with was a LED cornering bulb, the casing of which broke when I was installing. The seller replaced it without quibble.
Post #232930 5th Jan 2014 9:43am
Mark, the top ones look like the wrong pin fitment and the reverse look a bit to long , best measure the length available to be sure..
Post #232939 5th Jan 2014 10:48am
mjdronfield
Cheers Gents.
I've emailed the seller who lists the reversing light bulbs I've ordered as revers lights and the rr is under the compatible vehicles in the ad, so I await their reply, though can't imagine there will be a problem if I need to return them.
Stan, I did note your post about needing offset connection pins, but wanted to check my car first in case the orange/red units were different for some reason. I wanted to check before I actually placed the order anyway.
So, having been out to the car, I have bulbs with straight pins, ie not offset, and looking at the bulb holder, there are lots of cutouts in it, so whilst not knowing for sure, I'd imagine either would work.
Just ordered 2 packs of 2 now, so thats about £75 I have spent on the 6 indicators and reversing lights.
Indicator bulbs ;
Side repeaters ;
Reversing lights ;
Lets hope they hit the spot, as I'm after the car having modern lights with the original standard look.........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #232958 5th Jan 2014 11:50am
Ahh, loving the idea of the reverse lights Thumbs Up would you kindly report back on weather they are any brighter than standard please... Bow down ... I am desperate for some brighter replacements for mine (as they are massively duller than the D4 ones in the other car Crying or Very sad ) and we have a long reverse down our drive in the pitch black!
Don't much care about the colour just the brightness please sir Bow down
Post #232963 5th Jan 2014 12:08pm
pld118
@ mjd & C-T-C
You both have a PM re video link
Post #232986 5th Jan 2014 1:24pm
couldn't find any ref to what type of bulbs [pin wise] yours was Mark and i assumed they were like mine [offset]...good luck mate.. Thumbs Up
i did put some smd's i my reverse light son my td6 [still thinking they were 501's Confused ] and although brighter they didnt throw any more light ...
Post #232999 5th Jan 2014 2:17pm
pld118 wrote:
@ mjd & C-T-C
Thank you sir Bow down much appreciated Thumbs Up
Post #233005 5th Jan 2014 2:27pm
Page 3 of 5 <12345>
