Home > Maintenance & Mods (L322) > Stiff steering ( again ) . New spin on old problem .
coasterburner
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
Hi . My 2004 Vogue is unsteerable on tickover . It is overly stiff at 50 - 60 MPH on A roads . Call me old fashioned , but when I owned XJ6s in the early 1980s , the steering was featherlight at all speeds and you just got used to it . My P38 has no newfangled servotronic sh*te on it , but feels safe and solid at all speeds and in all conditions . My plan is to purchase a 12v to 9v reducer and plug it straight into the servotronic socket under the wheel arch . In theory , this should set the steering to the lighest setting at all times . Has anyone tried this already ? No amateur BS theories please . Realists only need reply .
http://www.ebay.co.uk/itm/261178043317?ssP...1438.l2649
Post #233064 5th Jan 2014 6:24pm
adigorn
well documented here
http://www.fullfatrr.com/forum/topic2.html
Post #233069 5th Jan 2014 6:36pm
coasterburner
All that gets me is hundreds of pages of assorted rubbish with no thread ????????????
Post #233070 5th Jan 2014 6:40pm
i cant see you getting much help with that attitude Evil or Very Mad
Post #233077 5th Jan 2014 7:20pm
coasterburner
No attitude intended . Meant as a question .
Post #233080 5th Jan 2014 7:25pm
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
"No amateur BS theories please. Realists only need apply" Whistle Laughing Rolling with laughter Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #233081 5th Jan 2014 7:27pm
coasterburner
Been told today I'm being made redundant next Saturday . Perhaps a tad too bladdered to be posting . Sorry guys .
Post #233091 5th Jan 2014 7:49pm
adigorn
ok than
problems with stiff steering comes from
a: power steering pump - sometimes revving engine up to 3000
loosen up stiff steering for a moment (than you have an answer)
sometimes pump is so dead that it doesn't not help either
b: mentioned by you servotronic valve -broken or short wiring etc
as valve is connected straight into BCU be careful as short in most cases leads into
BCU failure and stiff steering
I ve seen all - faulty wires faulty valves as well as faulty bcu's
Even if the wires have not been shorted and connector is still on place i would still suspect
bcu seen only one or 2 faulty valves in the past (however time is passing and have not worked on vehicle older than 2008 for a while)
If the wiring was broken and repaired and still no servo than its 99% bcu
Hope all that's enough realistic for the start
Post #233111 5th Jan 2014 8:44pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Mine was stiff when standing and ok on the move, i found the lower steering joint the problem a good few goes with wd40 and it got better then i put some light oil on steering a lot lighter now when standing on tickover. Also check your tyre pressure if they are low you will get stiffer steering at tickover.
Cheap fix for me and well worth a look at that first.
Post #233166 6th Jan 2014 10:15am
BCU & Servertronic valve are both under £100.
Post #233167 6th Jan 2014 10:17am
coasterburner
Thanks for the good advice . Will lube the joint when (if) the rain stops . Also , £100 seems very cheap for a BCU ?
Post #233213 6th Jan 2014 4:19pm
johnboyairey
still heavy steering....this might sound weird, but I had a good car till I fitted a dashcam, and used a piggyback fuse on I think fuse 41 in the glovebox. which I think said it was for the rain sensor. as I piggybacked it, sensor should still work. however on driving it, my steering was quite heavy, to the point I thought I had no fluid. (dashcam working etc) I did some initial power steering checks, and figured if I take out that piggyback fuse it might cure it, and it did. nothing in fusebox says it was connected to my steering system, but somehow it was.
have you done any wiring mods?
Post #249685 21st Mar 2014 9:18pm
maybe the servotronic valve is wired to that fuse John.. ... - .- -.
Post #249689 21st Mar 2014 9:24pm
johnboyairey
I saw that the servotronic is labelled as a different fuse number, but it certainly affected the steering, I didn't notice it immediately, and didn't link the two together as it was a different day when I drove it.
I need to piggyback from another fuse, what's yours on please Stan? and is it (piggy)fuse to left or to right?
Post #249709 21st Mar 2014 9:50pm
do you mean my dashcam?...if so ,i have it plugged in on my rse unit.. ... - .- -.
Post #249721 21st Mar 2014 10:39pm
