![]() | Home > For Sale & Wanted > Pre Heater remote - wanted |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075 ![]() ![]() ![]() |
Any one got one for sale?
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
Ebay. They seem to crop up there regularly for a fraction of the dealer cost.
Larry,
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
You are certain that your car has the heater yes?
It's in the touch screen options, so I'm guessing so, but I will check this weekend to see if I have the box of tricks under the nearside bumper. |
So FBH'S dont come as standard on diesel's , how much do the cost if retro fitted |
Sorry to dampen the flames but the remote won't work without the receiver and that is part of the TV receiver which is why it has such fantastic range , without changing the TV module it's no go I'm afraid. |
If I carn't be sure I'll get my dealer to check when it goes in for the common rear washer problem.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
sorry to hi jack your thread but is there a fix for the rear washer then as mine is a tiddy bit poor |
Is this why it only comes with the Vogue upwards? I hadn't heard this and assumed that the heater worked independently of the rest of the car, hence the separate remote. |
The fuel burning heather in the Range Rover is different to the FBH in the D3 or RRS in that it can do two jobs as a factory fit,first it is there to heat up the diesel engine on cold mornings to improve efficiency and uniquely by using the touch screen to control it can be used as a parking heater or timed heater. The Disco based vehicles have a FBH but it cant be controlled by the vehicle(a webasto timer can be fitted but it can't control the heating fan or ducts making it mostly useless)The remote control is another option that can be fitted but as we have discussed that means some expensive parts. |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Axle with you the crap FBH was one of the many reasons I changed to a FFRR from a D3 made sure several times it had the remote |
Mine hasn't got the controls on the touch screen or the remote. Not too bothered as the FBH has been a pure pain in the A55 due to a fault leading to a smoke screen everytime it kicks in.
You need a Vogue model with TV fitted Larry. Discovery 4 HSE
