![]() | Home > Maintenance & Mods (L322) > They do work - LED rear Tail/Fog light bulbs |
Here is the end result of this thread. A still image of the Supercharged rear tail/ fog aftermarket LED bulbs in situ and close up in the dark:
Thanks Alistair, anecdotally, I'd heard mention that in some cases, inserting LED bulbs in these 2 particular bulb housings could cause all of the lights not to work and was just wondering if they might cause damage to the car. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
Not heard that one - better wait for some proper experts before ordering any |
Reason for doing the rear is that the rear of the car currently has LED brake lights and indicators and I want a crisp uniform look as opposed to a mixture of halogen and LED.
I fitted some today. LED tail & fog light bulbs will work and perform/ look so much better than the OE incandescent bulbs. Error free. However, I experienced problems actually fitting and removing the below LED rear tail/ fog bulbs because:
The OE incandescent bulbs are single contact on the lower of these 2 bulbs (tail) & double contact on the upper of these 2 bulbs (tail/fog). The LED bulbs I was sent are all dual contact and the bayonet pins are set differently compared to the OE bulb pins.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
The pins are really easy to grind/sand sown slightly... Therefore the bulb wont get stuck when you fit it |
You have a PM Craig re video clip/ would be interested to know what you think of the direct comparison between incandescent OE and the aftermarket LED bulbs I refer to.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
@Craig, both Ryan and myself have the supercharged rear lights so they are clear lenses.... |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
At £16 they look a bargain! IIRC the red oem ones were almost £30 when I replaced last year Alcohol and eBay is never a good mix
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
So......you need to get 4 bulbs in total then ? for the 8 and 9 positions on the diagram, for each side.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
Would these be the correct ones then - http://www.ebay.co.uk/itm/2x-18LED-1156-58...483d03bb15 Got - 2017 SDV8 Autobiography in Loire Blue
to clarify,
@ mjdronfield - Certainly 4 x bulbs required for the tail/ rear fogs on the SC (2 each side of the car). The ones I bought were twin/dual filament 21/5W x 4 and all worked perfectly in each holder both tail and fog, apart from the need to amend the bayonet pin settings.
