Home > Maintenance & Mods (L322) > Jump starter that will fit in your pocket - how cool
May work on a battery just below the charge needed to start a RR but a completely flat/dead battery then no chance. (IMHO)
Post #233593 8th Jan 2014 3:48pm
Mph28mph
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Mr Tee wrote:
Sorely tempted, got another electrical drain, due to leave the car at the airport, either this or one of the solar chargers from Maplin. Car was completely dead in November after 1 week, battery has been replaced within the last 1.5 years, the joy continues.
Left mine at Manchester airport 10days over Christmas with a solar charger plugged in and working and still returned to a very flat battery.
I went to the terminal customer service and they sent one of their staff over with a battery pack, it happens regularly at airports.
Unfortunately the battery pack was only half charged so ended up getting green flag out. I was on the road later glad to be back in my ffrr instead of the horrible renault twingo hire car.
Post #233612 8th Jan 2014 6:33pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
left mine 2 weeks in august manchester airport ,solar charger plugged in was so dead could only unlock the drivers door , also AA mans jump starter wouldn't do it had to be jumped off his van after about 10 mins charge ,
just can't see that little battery jumping a FFRR.
Post #233647 8th Jan 2014 10:07pm
If you were to fit a battery isolating switch to your car you could leave it as long as you like at an airport etc and the battery would be fully charged when you came back.
Providing of course there was no internal fault in the battery causing a drain.... highly unlikely.
After switching the battery off, the car could be locked and unlocked using a key, the old fashioned way.
The car wouldn't be alarmed whilst locked but you have to chose a functioning alarm or a dead battery on return.
This obviously means your car has to have a key operated drivers door lock and that it works reliably every the time.
Isolating the battery means that should the worst happen and your door lock fails you would have no means of getting into the car unless of course you arranged to fit the battery isolating switch in an accessible position.
Although most battery isolating switches tend to incorporate a fused bye-pass circuit to allow the alarm to operate whilst the battery is isolated, this would have to be disconnected otherwise any battery drain on the car would simply carry on resulting in a flat battery as usual.
An alternative would be to carry a spare fully charged 110AH battery and a set of jump leads in the car when doing the airport thing. Thumbs Up
Post #233659 8th Jan 2014 10:34pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I got one of these for Xmas from my Grandfather after he'd seen them advertised in a Sunday paper supplement.
I'll keep it in the car just in case!!
Post #233708 9th Jan 2014 3:33am
ahebron
New Zealand
Boxes of Snake Oil if you ask me.
And if you dont ask me I will tell you anyway.
Adrian VW Amarok 2014 Highline auto
Post #235451 17th Jan 2014 4:44am
Stew_B
England 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I bought one of these mainly as a long life power supply for my laptop and phone.
I went out to my old tractor the other day and it wouldn't start, It would turn as far as compression but not past. I decided to try the little boost pack on it before trudging round the farm looking for the jump leads and much to my surprise it started up no problem. the cables from the pack got pretty hot though.
All in all im impressed with it. Oh and just incase your thinking it was a little petrol fergie, the tractor in question is a County 1174 fitted with a Ford 6.6L dieasl.
Stew
Post #238922 2nd Feb 2014 12:52pm
they work then.... Thumbs Up
Post #238925 2nd Feb 2014 1:01pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Saw this video on YouTube starting a car with capacitors. Maybe it is the same science behind it.
 Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #253575 9th Apr 2014 7:56pm
