![]() | Home > Technical (L322) > Reduced Battery Power |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
FSR?
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
I would be inclined to check the voltage on the car with the engine running at a fast idle. |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
After giving the battery a full charge, the light flashes & stays on intermittently during a 20 mile journey
You have an alternator problem which means it either needs refurbished or replaced.
Thanks for your prompt reply. So a new alternator. Any recommendations ? I seem to remember reading before it's an expensive part & a pia to fit |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
Exactly the same happened to me last weekend
Provided your car vin is below 5A999999 this will do you, unless you want a new genuine one at about £900.
Right enough a new alternator has sorted everything. Squeezed as much juice into the battery as possible overnight & set off to my indie 70 miles away for fitment. 20 miles in, the dreaded bong & lots of warning lights, stuck in 4th gear & couldn't risk a restart to reset. No heating, no lights, I even turned off the radio. Never thought I was gonna make it. It just shows how the car will keep the engine running but shut down everything else. On the return journey I noticed the seats & steering wheel toasty hot, wipers faster, a/c demisting properly and everything feeling good again. |
