![]() | Home > In Car Electronics (L322) > Audio fault help needed |
Water ingress rear left boot area
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Sounds similar to my issues Glyn.
Comports, you will confuse the OP by explaining the issues with your FF as its a PRE touchscreen and the OP's driving an SC so a post touchscreen model and therefore entirely different to your system/faults sir |
Glyn, open the boot and check the LHS compartment for water ingress. Usually runs down from the rubber boot seal failing/expanding in the top corners allowing damp in... You will need to check this thoroughly as when damp gets into the connectors/plugs it will start to grow green slime which corrodes the terminals and eventually they will snap off inside the plugs giving you intermittant problems/sound dropouts etc and will cost £££££ to change amps, ecu's, dvd players, BT units etc etc etc... Craig ![]() |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Try wiggling the speaker input / output plugs on the top of the DSP.
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
What/where is the DSP .? A pic possibly ?. |
Apologies Craig - Didn't spot it was a facelift |
Just noticed Craigs comment re possibly a Touchscreen you have if so My comments may not help you. It's the large black box rearmost in the LH rear side compartment. It has 3 plugs on the top of it, you want the rearmost plug and the front plug which have a load of speaker wires going into them. Be very gentle removing the plugs, the pins in the sockets on the DSP have a habit of corroding and breaking off. Picture below, Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
