![]() | Home > Technical (L322) > Chipped Windscreen - fix or replace |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Unless it's a big crack in the screen or an MOT failure I always get them repaired, a new screen never fits the car as well as the original one from build so if you can keep it, do so IMHO. Discovery 4 HSE
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
No issue I'm aware of. I've had several fleet vehicle done and it's never caused a problem. No melted resin or anything funky.
Get the screen replaced, you can see the resin, my previous screen had been repaired 3 times and you could see the resin in the screen, it was really bad under certain light. Also those area's never defrosted throughly.
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Alex,
I had a screen replaced in my old Disco2. They came back five times due to wind noise. By the time they had finished I'd wished I'd never asked them. Thick layer of gunge poking out from behind the trim panels trying to chase that elusive pin hole that was litting the air whistle in.
I had a screen replaced and they cut through every wire behind the rear view mirror! Disaster that took ages to fix correctly.
One point worth noting though. You can insist on a genuine screen if it has to be replaced. Just tell them when you book it. That's what I did on my D3 and I got a screen with all the LR logos etc.. I also gave the bloke an extra 20 quid to take his time and make a really nice job of it. Oh and a coffee with biscuits. Bribery and corruption? yes. Worth it? Definitely. |
It always pays to grease the wheels.... Discovery 4 HSE
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I had my screen repaired by Autoglass with their resin system and it worked fine. It was quite a noticeable chip but when they finished, all I could see was a small pencil tip looking mark on the windscreen. I currently have another chip on the upper part of the windscreen that is not visible from inside and they reckon that isn't repairable . They said they can use either LR screens or ones from Pilkingtons. I'm tempted by the Pilkingtons one myself as the windscreen is the only thing about the car I am disappointed with as it seems to scratch easily and when we had all the snow at the start of the year, the grit that hit the windscreen put mild scratches where the wiper blades hit it. Never had this issue on any other car I have owned and could only assume the glass was weaker as it had the heater element in it , but I don't know why it would be. I decided that the Pilkingtons version couldn't be any worse.
Resurrecting an old thread.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Hi Ryan, hope you are well.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 617 ![]() ![]() ![]() |
i have used this kit on mine does a good job only prob is the screen has about half elements working |
Garnerj Member Since: 07 Aug 2018 Location: Milton keynes Posts: 69 ![]() ![]() ![]() |
I'd be really interested to see the results of the DIY repair? |
Not too bad here Mark, hopefully you also 👍🏻
