Home > Technical (L322) > FBH Remote/ Receiver problem? |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Hi All
12th Jan 2014 1:45pm |
Thanks, I will try new batteries, but it is Duracell that I put in it 56 TDV8 Vogue SE
12th Jan 2014 5:09pm |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 |
Control the contacts befor you put the battery's in maybe slightly oxidated. |
12th Jan 2014 6:31pm |
I have tried new batteries and given the contacts a clean and this has not improved the range.
20th Jan 2014 1:58pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Have you checked the arial connection ? 2008 MY Supercharged
21st Jan 2014 2:11am |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
Probably daft question, but have you put the correct voltage battery in? Some RF fobs use 12v batteries that are physically the same size as 1.5v ones....I'm not familiar with the T89/90 one. 2007 TDV8 Vogue SE Java Black |
21st Jan 2014 1:33pm |
Axle, I have had a look in the rear compartment by the fuse box and the aerial connection looks and feels secure.
21st Jan 2014 10:21pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Is aerial on top or rear of fuse box ? I'm not sure if I have receiver as yet thanks. Present :2008 TDV8 HSE
21st Jan 2014 10:30pm |
The receiver uses the TV arial via the signal booster if memory serves me. 2008 MY Supercharged
22nd Jan 2014 2:03am |
Still can't get my FBH remote to work, so far I have tried the following
2nd Oct 2014 7:38pm |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
Is it cold enough for the fbh to fire up ?
4th Oct 2014 9:42am |
My guess is that it's the antenna connection in the remote fob that's bad. I think getting a new one from ebay would eliminate another variable, can always sell it on. 2007 TDV8 Vogue SE Java Black |
4th Oct 2014 11:14am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Can you not try someone else's fob on yours (if you have someone close by that doesn't mind you re synching thiers to yours for testing purposes) that would eliminate/prove the remote at least ? |
4th Oct 2014 4:02pm |
Not aware of anyone local to me with FFRR and an FBH remote.
4th Oct 2014 6:23pm |
