![]() | Home > Technical (L322) > Mystery Button in 54 vogue |
I you sure its not an AUX input fitted to play instead of CD?
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
is it some sort of immobiliser? Discovery 4 HSE
NoProDeluxe Member Since: 11 Jul 2010 Location: uk Posts: 24 ![]() ![]() |
Tried the ipod on the cd channel with and without cd's in but no joy. I'll write to the previous owner. |
I presume no joy on the AUX channel either? |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
why dont you press it when someone is sat in the passenger seat and see whats happens
Tried that, she didn't see the funny side............. ![]() |
have you tried plugging some headphones into it and see if its an audio feed rather than an input?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
thats what i thought it might be, with an on/off switch.. |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 ![]() ![]() |
Willing to bet it's an FM modulator... You're probably not hearing it because your stereo isn't tuned to the right frequency.
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I'm with Brad on this one, if the button kills the radio reception, it suggests that the input is being switched from the aerial input to a modulator , but modulators I have used in the past basically use a pre-set FM frequency (you normally have the option to change this manually to another 1/2 frequencies on the unit so as not to block out your favourite station) and your normal radio aerial plugs into the modulator which then has a plug which takes the place of the origianl aerial plug so as to carry its own FM signal to your unit. However, the RR doesn't use standard aerials so maybe yours totally switches between itself and the normal aerial, hence no radio signal at all when you press the switch. If this is the case, do as Brad says, plug the ipod in , get it playing a tune and do a search on the radio and most likely the first/only channel you will find is the ipod. Steve
any news gary? |
Sorry for not getting back sooner, having a very busy time at work. I think you are right about the ipod and I will have to just sit and go through the process of finding the right fequency. Thanks for your help I'll let you know as soon as I find it.
I tried having the radio on pressing the button on the, plugging in my ipod and running that, then a scanned through all the frequencies on FM, MW, AM etc...........nothing.
