![]() | Home > Maintenance & Mods (L322) > water pump coolant leak |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Well spotted... I take it you managed to tighten it up ok? Previously..
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
caught that in time.. |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
Yes cought in time and tightened up with the ratchet spanner, it's a pig of a job and you must get that tray off to get to it.
Hmm looks like the leak was this bit and the bolt on the water pump. |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
i have a similar v8, with the same leaks! my water pump 'gasket' seemed to be leaking, so changed it twice, still leaking! i eventually, left off the fan and cowl, to test it up to temp etc, and with a 'mirror on a stick' and a powerful torch, was able to see the cause, it turned out to be the actual aftermarket waterpump i fitted last year, has gone pourous! yes, it weeps fluid from around one of the casting 'webs' very odd! new one on now, and seems to be holding! underneath, the same transmission cooler area 'junction' connector piece, was leaking, but a little wrestling has sorted it, but will keep an eye on it. this three pipe junction piece, can be bought separate for about £30 -it seems to not be well secured, to me. when all ok, i will put my tray back on. lucky its not too cold yet, so i can drain, and add antifreeze at the weekend.
Update to the leak, as I had suspected the O ring was at fault so thought I would share. If you have a leak at this 4 way junction, clamp the 4 pipes ( I used small mole grips ), split the pipe off the main housing with a small screw driver which is retained with a wire retainer and just change the O ring, 20mm R11 type I used and all sorted. |
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
Satisfying! Good job |
Quite a common fault these O rings... Well done for finding which pipe, satisfying when you sort it |
| markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120
Thanks for advice. Out of interest welshdragon where did you get the o-rings from?
| All times are GMT |
