Home > Maintenance & Mods (L322) > They do work - LED rear Tail/Fog light bulbs
Page 2 of 3 <123>
s=single and d=double, are for the contacts on the bottom of the bulb..
the W,U, and Y are for the pin configuration..
s/c have clear/red bulbs,and i'm pretty sure the normal 2006-2009 have red/red bulbs
Post #233727 9th Jan 2014 8:50am
pld118
Thanks for that Stan.
As for pin configuration goes, as Craig suggested, if you want to do so, you can carefully file one of the pins down to amend the bulbs fit your own holders.
What's the difference/ any foreseeable issues with using double contact bayonet bases as opposed to single contact bases (obviously, the OE bulbs on the SC were double contact upper/ single contact lower and the LED bulbs I fitted were double contact. Both worked with no issues, regardless of the contact make up)?
Post #233770 9th Jan 2014 11:54am
normally with double contact bulbs one contact would be for tail for instance and the other for fog [21w/5w]
as one of the bulbs in ours has a single contact i assume that only one signal [5w tail] is going to that bulb so the double contact should be ok..i would check when the fogs are switched on to see that both bulbs are not illuminated..
Post #233772 9th Jan 2014 12:13pm
pld118
4 x free replacement rear tail/ fog LED arrived today to replace the first lot that broke due to the incorrect bayonet pin settings (with an invoice saying they are white and not red).
So I'll start filing down one of the bulb pins, modify it to fit and hopefully, that will prove that 'white' was a misprint and that they are indeed what I ordered... red! Wink
Really good seller though. Every time any issues with their bulbs, they've sent replacements without quibble and before even receiving my returns Thumbs Up
Post #234134 11th Jan 2014 7:41pm
pld118
Top tip
I've just safely, easily and quickly managed to fit the 4 x double contact dual filament replacement rear red tail/ fog bulbs thanks to a top tip from Cam Tech Craig that the bayonet pins can be filed down to make the bulbs fit into the bulb housing; and also thanks to a tip from Stan to only file down the bottom pin ensuring that the bulbs still sit securely once in the housing. Well in fact, despite carefully filing down the bottom pin on each bulb, both pins do still work to hold the bulb in place.
These 4 x rear LED bulbs cost £27.50 delivered, they work just the same way as the OE ones did and they look great when illuminated. A deeper, crisper, clearer and more consistent red than the OE incandescent bulbs and whilst brighter, they are not too bright at all and again, they do look OE. The fog light aspect of the bulbs also works. There are no errors or bulb warning with these bulbs.
Happy/ thanks for the tips Thumbs Up
http://www.ebay.co.uk/itm/1157-BAY15d-P21-...4572573901
Post #234765 14th Jan 2014 12:09pm
damn you Ryan, i have to go and buy some now... Laughing
glad it worked out ok on these.. its surprising that you even get any light from the OE bulbs considering the very small filaments but i suppose having two makes up for it..
btw , do the fogs work ok with the leds?
Post #234795 14th Jan 2014 1:42pm
pld118
Stan,
Damn yourself, you gave me part of the tip that resulted in the safe prep and installation of the bulbs. Without that, the replacement set of bulbs would have been powder in my hands... just as the first set were!
Rolling with laughter
Note - These bulbs cannot cope with being inserted or removed by means of hand manipulation into and out of the bulb holders via holding the upper plastic frame/ SMD light part. You must manipulate the lower, metal base from the area of the protruding rim downwards or you will damage the bulbs, guaranteed; and with these particular bulbs and the L322, you will only be able to do it properly by filing down the lower bayonet pin which takes seconds per bulb (they are well made bulbs, they are just not designed to be shoved in and pulled out via the upper part).
The top LED tail bulb (item 8 on thread starting diagram) appear to operate at twice the strength of the bottom LED tail bulb and I checked the SC with the rear LED in the offside and the OE bulbs working on the nearside and so, the LED bulbs are mimmicking what the OE bulbs do.
@ Stan - The rear LED fog bulbs do work and I tested them also, via side by side comparison with the OE fog bulbs. When the OE fogs iluminate, the effect is that it is more noticable than when activating the LED fogs but I consider the reason for that is because the OE tail bulbs are so poor/weak to start off with, when the OE fog aspect of this dual purpose bulb is illuminated, naturally the bulb boosts and becomes notably brighter. You do notice when the LED fog bulb is on and when it is off.
Post #234804 14th Jan 2014 2:08pm
very interesting , thanks mate.. Thumbs Up
Post #234807 14th Jan 2014 2:17pm
Wayne Grover
United Kingdom 2006 Range Rover Vogue SE TDV8 Cairns Blue
Oddly I think on my 2006 the upper dual filament bulb just uses the one filament - just a tail light with no fog - and the lower single filament uses a lower voltage as a tail light and higher voltage (12v) as a fog on the same single filament.
Post #245733 2nd Mar 2014 9:45am
correct wayne.. Thumbs Up
Post #245740 2nd Mar 2014 10:10am
pld118
Didn't last long!
After about 2 months use, one of four of these rear tail bulbs has failed. Rear fog error warning on dash and a check of the offside LED bulb found the bulb only partially illuminated.
Supplier HQ autobulbs UK says send it back to them, they will check it and hopefully replace as might be a manufacturing defect.
Has anyone else bought these and if so, how have they performed?
Post #280960 14th Sep 2014 5:36pm
Advanced Factors
Site Sponsor
I Have a version of that:
http://www.advancedfactors.co.uk/380-red-5...5658-p.asp Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #281525 17th Sep 2014 11:20am
pld118
Yours look of a much more robust and solid design than the ones I've used Steve... and cheaper!
Yours are designed like the front sidelight LED upgrade bulbs I bought.
Also, with my LED tail fog bulbs I had to file down the bayonet fixing pins as the pin offsets were not an exact match for the L322 bulb holder. I take it yours don't require any such messing?
Thanks
Post #281527 17th Sep 2014 11:36am
Advanced Factors
Site Sponsor
Sorry these would be the same pin arrangement as the ones in your ebag link, I will sort my next bulb order in the coming couple of days so will have an option for you in a few weeks if you want.
However, yes robust lot, I quite like this manufacturer, they do things by the book by my experience so far. Paul Redding
+44 (0)23 8052 2760
Post #281529 17th Sep 2014 11:52am
Petru
Russia 2007 Range Rover Supercharged 4.2 SC V8 Baltic Blue
Can anyone tell me the reason why the upper dual filament bulb just uses the one filament (5W) for the tail lamp, with the 21W filament not used by any function. And the lower single filament uses a lower voltage as a tail light and higher voltage (12v) as a fog on the same single filament.
Any logic?
Post #358245 23rd Nov 2015 1:37pm
Page 2 of 3 <123>
