![]() | Home > In Car Electronics (L322) > Freeview TV Guide |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
its nothing like the freeview you get on a standard tv ...there's no epg or radio stations.. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988 ![]() ![]() ![]() |
I get Freeview exactly as at home including radio stations.
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
It seems to pick up 1 station at a time and only by changing from PALB to PAL I (for example) will it pick up a different channel. Don't know if there are any '753 hack' settings that I could amend to make it work. btw it's a 2006 S/C |
Andy is referring to the OE hybrid tuner NDFI...the aftermarket jobbys will be the same as the normal house tv's...
Thanks chaps, the setting is on 'United Kingdom' but the 'Auto' button doesn't seem to do anything....neither does the manual tune for that matter! It's all a bit strange |
not sure on this one Andy, maybe a battery reset or [guessing now] you might have to do something in the ccf to active the tuner ? |
Thanks Stan. It has recently had a reset due to a battery replacement and also at the last service they had to do a hard re-boot as the ECU locked out and wouldn't reset the service indicator (Range Rovers, don't you just luv 'em!). What is the ccf (please excuse my ignorance!).
ccf= car configuration file.
Cheers Stan, that's really helpful thanks.
an IIDtool would be a wise investment as it can also clear faults.. |
Cheers Stan, was looking at these before Xmas and they look good value. Maybe time to invest methinks!
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
The factory fitted hybrid digital tuner has no EPG, but the later units have it. I have EPG along the bottom of the screen. Current: TDV8 (3.6) RRS HSE
on your 2007 Stu? |
