Home > In Car Electronics (L322) > Nav screen illuminating whilst vehicle unattended.
Andy
Got a call last night from my wife telling me that the Nav screen was on showing the splash screen. It then went off and came back on a short time later.
All this whilst the car was sat on the drive locked and not driven for a day or so.
Anyone know why this does this?
Post #235092 15th Jan 2014 2:23pm
I could be way off with this, but... I believe the system wakes up and checks the air suspension every so often. I know this because I had a leak in a hose and it kept trying to level, until the reservoir was empty, even when switched off. I was thinking you have something waking up? Previously..
Post #235103 15th Jan 2014 3:11pm
Andy
I've never seen that before. I'll keep an eye on that. Cheers
Post #235109 15th Jan 2014 4:12pm
jak480
Norway 2003 Range Rover Vogue Td6 Zambezi Silver
Splash screen is showing every time the system wakes up something is definitely waking it up could be the suspension but also other systems that are connected to the I-bus ( radio,nav,light module,...) if it happens often it wil drain you're battery quickly as it uses several amps to wake the modules. Shocked
Post #235397 16th Jan 2014 9:36pm
External radio interference?
Post #235402 16th Jan 2014 9:51pm
The old favorite water ingress in the LHS of the boot... Check for damp and do a battery reset Thumbs Up
Post #235404 16th Jan 2014 10:03pm
Andy
Just been woken by the cars alarm. Bleeps for a few seconds, stops then does it again.
I went out to the car and the little amber LED near the gear selector is on, along with one on the drivers door window switches. All doors are locked.
I'm hoping this isn't a repeat of last year when I had to have a new battery Evil or Very Mad
Post #235450 17th Jan 2014 4:25am
bonnet alarm sensor Noddy...they get corroded or stuck ......
Post #235475 17th Jan 2014 10:06am
