![]() | Home > Maintenance & Mods (L322) > Rear fog at reduced output |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
does the OE bulb work ok? |
Yes Stan OE bulb was ok |
i suspect the bottom contacts on the led bulb are not placed in the correct position ..as you know one is for tail and the other for fog so they need to marry up with the appropriate source..
Good point Stan! very good point.. you should join one of those Range Rover forum thingies! |
