Home > Technical (L322) > Fuel Tank
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Fuel Tank
Quick question for the Yoda's of the forum (Cam tech I'm looking at you!)
Are the 02-06 td6 and V8 fuel tanks the same?
If I bought a V8 one would it work in my TD6 if I swapped all the gubbins over?
The reason I ask is after replacing the tank pump at Xmas we noticed there's a lot of gunge in the bottom of the tank.
Obviously after dropping the tank and jet washing it all out it would need to dry out for a few days. So in a bid to do it in a day a second hand tank is required. The plan is to clean it out ahead of time then just swap them over. I can then clean my one out and punt it on.
For some reason though the td6 tanks seem to go for around 3 times the price of the V8 ones!!
They look very similar.
Any help greatly received.
Post #235594 17th Jan 2014 8:41pm
Sorry Paul, i have absolutely no idea Whistle Have never had one out/changed one im afraid... Check with Dan maybe?
Post #235599 17th Jan 2014 9:02pm
paul271
Will do Craig. They look damn near identical!
Post #235603 17th Jan 2014 9:28pm
i'd look at the ancillaries for each tank and if they are the same then the tanks must be..
Post #235619 17th Jan 2014 10:49pm
Have a look on the microcat at the part numbers, there seems to be slightly different part no depending on vin between different td6 but they seem to correspond to the same vin changes in the v8 as well have a look and you will see what I mean Thumbs Up
www.lrparts.ru There is nothing that can't be fixed with a hammer😜😜
Post #235620 17th Jan 2014 10:50pm
paul271
Cheers for the feedback so far chaps.
Post #235639 18th Jan 2014 12:26am
Im pretty sure the tanks are the same.
Once the tank is off the car and jet washed just pour very hot water into the tank as the final flush and then get a towel out and dry it out.
Any tin remains of water in the tank will be dropped out by the diesel anyway(there is a water trap in the system) and wont affect the running of the car. Just prime the fuel system a few times before cranking it over. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #236243 21st Jan 2014 12:21pm
paul271
Cheers Pleb. I've been comparing pics and they look identical.
Post #236351 21st Jan 2014 9:27pm
Noddysvogue
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Hi paul
i have a spare bare tank which i bought for the pumps for sale if interested
Post #238774 1st Feb 2014 6:38pm
paul271
Very much so mate. Was it out of a Td6 per chance?
Post #238813 1st Feb 2014 9:41pm
Noddysvogue
Hi Paul
Yes is for a td6 mine used to breakdown with 100 miles left due to pumps so stripped it down and swapped them over
Would take £20 +pp unless you want to arrange your own courier
Ian
Post #238819 1st Feb 2014 10:16pm
paul271
That sounds perfect to me mate. If you can ship it then I'm quite happy to pay it. I'm at work just now so I'll pm you tomorrow and we can sort it all out if that's ok?
Post #238821 1st Feb 2014 10:28pm
Noddysvogue
Yes that's fine
Post #238827 1st Feb 2014 10:42pm
paul271
Your an absolute star sir. Thank you.
Post #238831 1st Feb 2014 10:52pm
