![]() | Home > Maintenance & Mods (L322) > Car sounds like a fridge.. No it's a whirly noise! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Is it the fridge ? |
The trail seems have gone cold! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
loose brake shield |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Wheel bearing? There is nothing that can't be fixed with a hammer😜😜
Thanks for the suggestions.
Does it get louder on right hand sweeping sections of motorway?/bends There is nothing that can't be fixed with a hammer😜😜
Ragerover Member Since: 02 Feb 2011 Location: Newcastle Posts: 220 ![]() ![]() ![]() |
Does the light me on when you open the door ?
Sorry Ragerover, you and your pals might think you're cool with replies like that but they leave me cold |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
Usually when a wheel bearing starts to go, other than having play in the wheel when it's off the floor, the centre of the wheel gets warm from the heat from the failing bearings, so if you put the palm of your hand on the centre of the alloys after a run, one May feel warmer than the other 3.
Seriously though
you can check the brake cover by raising it to full off road height and gripping the cover and trying to move it. There's loads of info on here. Washers can be a simple, cheap solution. |
Thanks for the replies to date:
I've currently got the car on the jack with the front offside wheel off.
