Home > Technical (L322) > Questions about my new L322 4.4 FFRR!
Page 4 of 5 <12345>
can you update your FF profile so we know what one you have...
i gather yours is a 2002-2005 model..
any discolouration can be a sign of the bulb on its way out and tbh for about £15 upwards per pair you can get some 6000k xenon bulbs of ebay which will give you a nicer whither light than the OE colour and then you can keep the good bulb thats left as a spare..
Post #236011 20th Jan 2014 10:24am
MariusRR
Norway 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Cool!
Found some bulbs in Oslo at a good price. Is it straight forward to change them or is there anything special I need to look at?
Post #236048 20th Jan 2014 2:48pm
MariusRR
stan wrote:
the dealer should have turned the steering wheel fully to the left and then fully to the right after the jump start, if he didnt then the errors will show..
i suggest disconnecting the battery and do this procedure , how to is in the wiki..
there is also the possibility that the battery is knackered..
Had a look at the wiki. Is it enough to disconnect the earth and leaving for 20 min to have the system reset?
Post #236050 20th Jan 2014 2:51pm
easy to fit, but make sure you get the bulbs with the anti vibration metal strips like in this pic,
re the battery, best to disconnect the positive..
Post #236051 20th Jan 2014 2:52pm
MariusRR
This is the bulb I found. Its got the strip right?
Post #236052 20th Jan 2014 2:57pm
looks like the right one Thumbs Up
Post #236054 20th Jan 2014 3:06pm
MariusRR
Update: Put the battery on a charger last nite. The charger I used has a scale from 1 to 8. I had 3 bars when I started charging it.
Also fittet new xenon bulbs, and it shines like a beauty again.
But I have discovered another weird thing. There is a small shudder when the car is shifting gears around 50-55 km/h. Have to pay attention to notice it, but still there. If I change gears "manually" its not there.
Post #236210 21st Jan 2014 9:46am
MariusRR
Another question. How do I get the list over equipment fittet to the car when new?
Post #236288 21st Jan 2014 4:32pm
MariusRR
So. I have now gotten the error codes read. Lots of voltage related errorcodes. All cleared, and the car is silky smooth again. Very happy. I have also contactet an LR-importer and gotten the list of equipment fitted.
New problem is: It never seems to get very warm in the car. I have checked fluid levels, and there is plenty of coolant on it. It had a full service before I bought it, were they filled it with new coolant as well. In BMWs lack of furnice-type heat is a sign of to little coolant. Or something else in the area of the coolant system. Very interested in feedback on this!
Post #236648 23rd Jan 2014 4:33pm
Dolphinboy
themostat? might need a new one. Or have the aircon recharged?
Post #236705 23rd Jan 2014 9:47pm
MariusRR
Thanks!
Do ayone know how if the thermostat is the same on bmws and l322, on the m62b44 engine?
Post #236765 24th Jan 2014 10:11am
MariusRR
Same partsnumber on the one for BMW and LR
Here is a picture of my expansiontank
Post #236781 24th Jan 2014 11:33am
MariusRR
Now the sound disappered, and the DSP disappeared from the menu. Not happy
Post #236964 25th Jan 2014 12:00am
MariusRR
Can anyone point me towards a guide to dismantling the DSP?
Where is the fuse on the radio unit?
Post #236995 25th Jan 2014 10:09am
MariusRR
DSP working again!
Post #237006 25th Jan 2014 11:28am
Page 4 of 5 <12345>
