![]() | Home > Maintenance & Mods (L322) > supercharged rear bulb replacement |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
following on from replacing my rear clear s/c indicator bulbs with cree bulbs and encouraged by pld118 efforts, i today replaced my OE bulbs with cheap smds and although the fog is slightly dimmer than OE ,these smds give a more redder uniformed light..
good job Ryan, its surprising how much these smds fill the whole lens with equal light.. |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
They both look really good chaps |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Thanks. They are superb... The LED tail/fog bulbs are quite well made but can be fragile bulbs at the point of fitting ('mine' are anyway) but once you live and learn as to how to handle these particular bulbs at the point of fitting them; and having acquired tips of the trade on how to file/tweak the bayonet pins when required, the results are more than pleasing.
thanks Jason |
some night time pics,
Good depth Stan |
works ok but not as bright as the OE bulbs... |
They look very impressive and not using any juice. |
Or are the OE tail bulbs so poor hence the OE fog looks brighter whereas the car is now visible with the LED tail such that it's less noteworthy when the LED fog comes on
| rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496
Looks very nice. Did I see somewhere that you had done the indicators as well (searched but can find link) Is there a link to get all the correct bulbs from one place? Am I correct in understanding that you have to file a pin off each bulb to make it fit the FFRR. There is a difference between knowing your sh!t and knowing you're sh!t
they dont make red smd bulbs with the correct pin config for the clear s/c units so hence the 'adaptation' of standard smd bulbs, its just a matter of filing one of the pins so you get a friction fit rather than a 'click in the socket' type.. |
^^ my thoughts exactly Ryan...the new smd bulbs are brighter so the progress in light output to fog is smaller..anyway i cant remember the last time i used fogs... |
@rej - Re your queries on bulbs.
| All times are GMT |
