Home > Technical (L322) > gearbox thud
lex99
this is baaaad news! craig.. pm coming your way.
Post #212579 26th Sep 2013 11:28pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Question. When a LR dealer / Indy (whoever) reflashes the gearbox software do the adaptions need to be reset too? Or can the new software be flashed without the adaption reset? 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #237284 26th Jan 2014 7:31pm
T24RES
Ive re-read the whole thread, when reflashing software resetting the adaptation is required.
Post #237300 26th Jan 2014 7:56pm
The Big Gearbox places like A1 Premier Transmissions will do an overhaul for under £2k but complete rebuild £2.5-3k.
Any then there's that place in Germany..... Idea
Post #237314 26th Jan 2014 8:28pm
TugRR
Forgive my ignorance here, but aren't the symptoms Salb is experiencing common with the ZF 6 speed gearbox ?
Mine does it to some extent (although 4.4 AJV8) when changing down.
I made a note some time ago (can't remember if it was from the Forum or not . . . ) of a Technical Bulletin, titled:
Gearbox Upgrade LTB 00267
"Harsh Transmission (1 - 2) & (2 - 3) Lift Off Throttle and (3 - 2) & (2 - 1) Rollout"
Is this the "upgrade" mentioned by others ?
Thumbs Up Where do you go after one of these . . . ?
Post #237427 27th Jan 2014 11:53am
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
hi,
well i have done nothing and left it and now probably done another 10,000 miles
and its only now and then, in fact i dont even notice it now.......
sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #237487 27th Jan 2014 5:25pm
auzzzie
Canada 2008 Range Rover Supercharged 4.2 SC V8 Barolo Black
Cam-Tech-Craig wrote:
Sal if anything, take it to a Land Rover dealer/tech who can re-flash the gearbox software. If the oil is changed on a SC gearbox then it can lead to preload issues from the transfer box. Never get the oil changed and adaptions reset as it often causes premature failure... Lots of technical stuff im afraid!
If it helps, PM me and i'll forward you the details we were sent by LandRover about the above. Warning us not to.
Craig Thumbs Up
Craig,
I realize this is an old thread but I was hoping you might be able to PM me that information. I'm currently trying to decide if I should change the fluid in my 6HP26 or not. Very hard decision when multiple professionals have different opinions.
If your opinion has changed or you have any info from LR you can pass on would be much appreciated.
Cheers
Post #283977 1st Oct 2014 7:26pm
RR2008HSE
I'd be interested too.
Thanks Bow down
Post #284041 2nd Oct 2014 2:25am
Mikey
Unnecessary quote removed
The official oil change interval from ZF is 75k, reduced to 50k if you do a lot of towing.
I changed the oil in my own gearbox t 115k miles, but it was too late at that point. The damage was done, and the box is Censored
FWIW, I have also flushed 3 S/C models, between FFRR + RRS, and never had an issue, though they were all under 100k Thumbs Up
Post #284044 2nd Oct 2014 7:12am
ebajema
Before the 5.0 SC is shipped to Malaysia, I will have the ATF and filter replaced. Ideally first a Megaflush and then filter change so the oil is as clean/fresh as possible. MY 2010 5.0 SC Galway green and sand interior!!
Post #284046 2nd Oct 2014 7:43am
salb
Hi Mikey,
Who has done your oil changes on the gear box, I'm in lancashire and an still looking for someone
who can do it.
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #284055 2nd Oct 2014 8:51am
Mikey
I do mine myself.
Can't say too much, as not a sponsor here, but I am a sponsor on D3 and RRS sites Thumbs Up
Post #284093 2nd Oct 2014 3:26pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I'm so confused. I'm 500 miles away from 100k and wanted to get a megaflush and then filter swap/top up etc.
1. I don't know anywhere near me that does that
2. I don't want to knacker my Transfer box!
No idea what to do. Neutral
Post #284304 3rd Oct 2014 8:25pm
