![]() | Home > In Car Electronics (L322) > Sat Nav Upgrade |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7917 ![]() ![]() ![]() |
These cars only ever had the BMW mk3 sat nav as standard. The upgrade unit is a BMW mk4 unit, and as it was never fitted to a land rover will not be a land rover part / part number.
Something like this
If it doesn't fit you have the wrong one - the MKIV is a direct plug in replacement - as per Mr Dronfield. |
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 ![]() ![]() ![]() |
Can I ask a stupid question, but what are the benefits of changing? What makes the Mk4 better than the RR unit? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35679 ![]() ![]() |
the mk4 is dvd based as opposed to the OE nav which is cd .. |
The MK IV is horrible, but it does work.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I did the upgrade from mk3 to mk4 and it works great. but I am stuck with the bmw logo. mine was from a mini I believe. I tried to burn a RR splashscreen but it sent it a bit haywire, and blue screened it for a while. I tried a couple of different burns, but managed to get it working again. but still on the bmw logo. its a good nav, for its neatness and ease of use. though I need the name of road as not currently doing a 7 digit postcode. is there a better way of getting said RR splashscreen, and 7 digit postcode? anyone got a spare upgrade disc? I have looke dall round forums. and its currently on the latest software, (from memory) I think I need to 'back version', and then 'up version'. but im at a loss....
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
I did matts splash screen , everything was fine |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I burnt Matts software and it's fine. However, for some reason I can't turn off speed camera alerts anymore and the scale has changed in that the 75 yards option isn't there anymore. |
isnt it that you have to change the language to french fist and then you can switch off the speedcams..i'm probably wrong here though .... |
I'll try that.
ah, you broke it then |
Possibly! |
