Home > Technical (L322) > Just a click, but no start |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
29th Jan 2014 8:27pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
Hi have seen that post but this 'click' has only started since I changed the battery.
29th Jan 2014 8:34pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
I would concentrate on the possibility of a bad connection to the battery, either one or both terminals.
29th Jan 2014 8:45pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
^+1 Previously..
29th Jan 2014 9:07pm |
My old TDV8 used to do that. In the end it turned out to be a dodgy solenoid on the side of the starter. For expediency I got the starter refurbished by a place in Birmingham. they did it while I waited and it cost me 60 quid. Was fine after that.
29th Jan 2014 9:23pm |
Will try the copper surround to terminals first.
29th Jan 2014 9:29pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2027 |
I had a similar click problem, but it was hardly a click at all, it turned out that although the neg battery terminal was tight, it wasn't bedded down on the post properly, so looking at it now it has about 3mm of post coming out the top, I then tapped down the posi too to make sure. the terminal was tight on the spanner but not holding with enough force to carry the amps. it went iffy if a had the headlamps on or had been leaving ign on for about 15 mins etc.
29th Jan 2014 9:48pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
i had same symptom for 12 months, sometimes just a click, turn key back try again and starts
29th Jan 2014 11:38pm |
