Home > Maintenance & Mods (L322) > heated rear window
joebenz
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
heated rear window
Hi guru's Bow down , does anyone else have the problem of the rear window taking ages (sometimes upto 15 mins)to clear? (i have a 2004 td6)
Post #237573 28th Jan 2014 8:45am
T24RES
Is the spare wheel well dry? Excess moisture can live in here. But to your question, I rarely put it on due to the A/C sorting out the damp air.
Post #237710 28th Jan 2014 4:01pm
joebenz
i noticed the boot floor was wet the other day when i was changing the inner boot bulb. do you know how do i fix it?
Post #238034 29th Jan 2014 8:12pm
search 'water shedder' and all will be revealed..
Post #238038 29th Jan 2014 8:18pm
or the tailgate seal .
Post #238051 29th Jan 2014 9:21pm
joebenz
checking now
Post #238057 29th Jan 2014 9:37pm
joebenz
so went to land rover and they said that they don't do a water shedder for my car!?
can anyone suggest anything to help?
Post #243505 18th Feb 2014 10:26pm
mjdronfield
I'm sure i posted up a part number for the shedder, just order one of them. Same as my car.
Parts guy needs to check again.
Here you go.......
EOT500030
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #243523 18th Feb 2014 11:01pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I have the water shedder but I can't find any instructions anywhere how to actually fit it. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #243526 18th Feb 2014 11:11pm
one of these threads will probably help,
http://www.fullfatrr.com/forum/search.php?...rch_time=0
Post #243529 18th Feb 2014 11:15pm
joebenz
Thanks... will order tonight Smile
He said when he check direct with land rover my vin number said they didn't make one!!
Post #243572 19th Feb 2014 8:25am
mjdronfield
@rej, if you are still stuck fitting, here is a pic.
Not my car, someone on here I believe.
I slid mine behind the units without taking the frame out.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #243902 20th Feb 2014 8:15pm
rej
Thanks. The supplying dealer is found to try and sort the leak when they take the car back. I will try and got thereafter shedder at the weekend if dry. Only dampness evident is around the spare wheel, nothing obvious in the sides. Is the seal most likely? There is a difference between knowing your sh!t and knowing you're sh!t
Post #243968 21st Feb 2014 10:27am
mjdronfield
Mine has never leaked, did the shedder as a precaution.
Others do seem to say change the rear tailgate seal first, though I understand it can come in where the rear bumper bolts on.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #243972 21st Feb 2014 10:54am
Whilst a water shedder may well stop water leaking into a car cascading over the valuable electrical gubbins located in the rear compartment it does not stop the water coming into the car in the first place and in the right conditions going on to form condensation over all the components including those under the shedder.
Dubious piece of plastic sheet in my opinion. Wink
The condensation in the car is almost certainly caused by a faulty upper tailgate door seal. They appear to usually fail at the top left corner of the opening. Any water leaking into the car will then track thro various body cavities and collect in the left rear compartment and/or the spare wheel well.
I would advise checking the tailgate door seal and if the top left corner is loose/distorted invest in a new one from Dan@Duckworths.
Well worth the money to have a dry car. Thumbs Up
Post #243978 21st Feb 2014 11:38am
