Home > Maintenance & Mods (L322) > Tools everyone should know about (please add)
Page 2 of 3 <123>
4 post ramp, everyone should have one
Post #238391 31st Jan 2014 1:37am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
An original SuperTool, countless times it has helped fixed things from Audi UR Quattros to Zips, when access to normal tools has not been possible Thumbs Up Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #238405 31st Jan 2014 6:46am
WD40, and when that doesn't work - silicon sealant. Thumbs Up
Post #238417 31st Jan 2014 9:00am
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
A selection of big think pieces of timber about a yard long. Great substitute for a garage lift and for small people to stand on when working under the bonnet.
Also useful trip hazard for the wife when she comes in during hours of darkness. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #238445 31st Jan 2014 10:50am
pld118
Duck tape wrapped around the business end of the wheel brace... stops the alloys getting chipped and scratched when manually loosening/ tightening wheel nuts.
Post #238455 31st Jan 2014 11:21am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Home made large T bar, made from 2 pieces of scaffolding pipe welded into a T.
The top of the T has a 3/4 inch drive adapter welded in one end and the other end has an old Land Rover wheel nut socket.
The handle is about 3 feet long and when dealing with tight wheel nuts the other end of the T can be supported by a extra jack.
Ian
Post #238457 31st Jan 2014 11:32am
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
FullFatRR Forum on ur phone
Post #238460 31st Jan 2014 11:46am
The proper use for Duct Tape Shocked Shocked Shocked
Post #238490 31st Jan 2014 2:47pm
steptoe
Quality head torch.
Post #238601 31st Jan 2014 9:04pm
T24RES
Along with the other fine suggestions I find these very handy.
Post #238603 31st Jan 2014 9:41pm
klf400
be carefull with those toffee wheels if you get to heavy they will mark the lacquer/paint Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #238820 1st Feb 2014 10:21pm
pld118
Mr Muscle
Mr Muscle... wheels and other uses. Just type 'Mr Muscle' in the forum search engine Thumbs Up
Post #238829 1st Feb 2014 10:46pm
You need to be careful on cheaper quality re-paint's too...
Post #238834 1st Feb 2014 11:15pm
S33MAF
2014 Range Rover Autobiography SDV6 Baltic Blue
Metric adjustable spanner.
Post #247175 8th Mar 2014 11:34pm
steptoe
Forget the adjustable - If you want one emergency tool for undoing nuts and bolts, you need one of these.
Post #247349 10th Mar 2014 12:41pm
Page 2 of 3 <123>
