Home > Technical (L322) > 3 of my front parking sensors have suddenly stopped working
redshovel
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
3 of my front parking sensors have suddenly stopped working.
The far near side sensor is operational and beeping as normal – but the rest do not cause a beep when approaching an obstacle.
I have checked and confirmed all the front sensors are making a ‘ticking’ sound.
There is no error warning sound/flashing light when activating the PDC.
I disconnected the parking ECU for an hour and reconnected it with the vain hope it would reset something/anything…..but made no difference.
Wiring fault or new parking ECU needed???
Post #239013 2nd Feb 2014 7:09pm
redshovel
Any thoughts on this at all??
I have searched other posts relating to the PDC system but all seem to relate to either the sensors failing completely at one end or one or more failing and a solid error beep sounding.
Post #239106 2nd Feb 2014 11:31pm
normally if the sensor clicks then it should beep when there's an object in its way, why yours is doing one and not the other i dont know....
maybe dry out the sensor as much as possible [hairdryer?]
check out the wiring, maybe one crucial wire is broken?
complete battery disconnection..
Post #239166 3rd Feb 2014 9:54am
mzplcg
Which one is working? Is it one of the end ones by any chance? If so I suspect a break in the wiring after the one which is working. Might be worth buzzing the cables through.
Post #239167 3rd Feb 2014 9:56am
redshovel
Yes far nearside one is working normally....when it stops raining I will take bumper off and check out the wiring.
Post #239192 3rd Feb 2014 11:02am
