![]() | Home > Technical (L322) > TD6 2002 wont start |
Batpooh Member Since: 28 Jan 2014 Location: Aylesbury Posts: 13 ![]() ![]() ![]() |
Hi All first post and as usual its a cry for help |
That's a good way of describing the problem - with a video.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
To eliminate gear selector cable stiffness / corrosion holding off the gearbox inhibitor switch I would be inclined to lubricate the cable as per the link below,
Video very handy.
Easiest thing to do is unplug it and see what happens?
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Could it be a bad earth? Try putting a jump lead from the negative on the battery to the engine. '04 td6 se
Sorry for the delay,
When you first lock the car you could see 6-7A being drawn from the battery, possibly slightly more of the FBH has been running whilst it goes thro its purge cycle.
So i should get a reading of 0.03 amps on the fluke |
Still think its a bad connection somewhere. If you look at the instrument panel the only light thats flashing is the oil light which points the problem towards the engine side of things in my opinion. The relay thats ticking in the engine compartment is the glowplug relay which draws quite a bit of current. Double check all your main earth and power cables for good connections. Check the main fuses by pulling them out and checking their terminals are clean etc. Remember to disconnect the battery first though. If it were the ignition switch then i would imagine all the warning lights would be flashing???? Good luck |
Try this,
Noddysvogue Member Since: 01 Feb 2014 Location: Blackpool Posts: 4 ![]() ![]() ![]() |
Hi Stuart I've noticed the hill decent is lit on your clocks has it always done that as mine doesn't light on start
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
As Ian says and also the oil light is flashing, dont think mine flashes like that.
Hi Folks
