Home > In Car Electronics (L322) > Radio problem
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
Radio problem
06 TDV8 radio shows the Land Rover logo and the on off button is flashing but the radio will not switch on? Can switch on the FBH via the dash switch but the button did not illuminate?
Post #238874 2nd Feb 2014 9:20am
battery?
Post #238878 2nd Feb 2014 9:47am
More than likely your bluetooth module my friend... Water ingress? Check for wet in it, then check top left boot seal and see if its expanded and rippled on the corner Thumbs Up
Post #238885 2nd Feb 2014 10:42am
gg2201
Mine went similar to this just before we discovered our battery wasn't up to scratch so replaced the battery. New battery = problem solved so perhaps yours is the same? 2011 4.4 TDV8 Autobiography
Post #238926 2nd Feb 2014 1:02pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Check this -same issue. Check spare wheel well for water and the left hand side boot seal. Built badly but look good;
http://www.fullfatrr.com/forum/topic22942.html
Post #239092 2nd Feb 2014 10:40pm
So dry out the rear, check all connections for corrosion etc., try battery charge and battery disconnection procedure.... .
Post #239095 2nd Feb 2014 10:47pm
Harris
Water via tailgate seal, fixed, cured
Post #244702 24th Feb 2014 8:57pm
Post #244704 24th Feb 2014 9:23pm
