Home > Technical (L322) > warning
Bozzy1954
England 2003 Range Rover HSE 4.4 V8 Epsom Green
warning
Just had a warning come up when I switched of the ign,Trans fail safe prog, am I looking at a new gearbox or electrical problem? Crying or Very sad
Post #239270 3rd Feb 2014 4:14pm
Maybe either? 1st check the electricals... Battery charged? Any good?
Post #239275 3rd Feb 2014 4:19pm
Bozzy1954
Hi thanks for the reply, I have had to have the car jump started due to it not being used for a few mnths, just had a new frontend and rearend after a snow plough pushed it of the road. I just took it for a run 30mls is that enough to fully charge the batt.?
Post #239278 3rd Feb 2014 4:33pm
did you set the steering parameters?
Post #239281 3rd Feb 2014 4:34pm
Bozzy1954
I only fitted the panels,a garage did all the fiddly bits, the front was only cosmetic just upgraded to the face lift front.
Post #239285 3rd Feb 2014 4:43pm
when the battery is replaced or goes flat ,you have to turn the steering wheel fully left then fully right..try disconnecting the battery and follow this procedure, details are in the wiki.........
Post #239286 3rd Feb 2014 4:44pm
Bozzy1954
Ok I'll give that a try.
Post #239288 3rd Feb 2014 4:48pm
Bozzy1954
Panic over just a sensor playing up, reset its self now. Thanks for your imput, Embarassed
Post #239294 3rd Feb 2014 5:37pm
dan_uk_1984
If your battery has been flat for a while keep an eye on it. You only get 2/3 deep discharges out of a battery before the plates are knackered and it will never hold a full charge again.
Post #239300 3rd Feb 2014 5:53pm
Bozzy1954
Thanks for the info, because I'm away a lot the car does not get used a great deal.
Post #239303 3rd Feb 2014 6:04pm
