Home > Maintenance & Mods (L322) > steering tilt spindle and drive spindle bar problem.. |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Are these links any good to you?
4th Feb 2014 8:45pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6350 |
You could buy a second hand tilt motor thats proven to work and save LOADS on a new one, dead easy to fit.
4th Feb 2014 9:00pm |
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 |
thanks for the link welshdragon, RRUK the problem is not with the motor,its with the tilt spindle that can be seen in the link,its not making contact to the drive spindle thats part of the motor,,so when the motor turns,it drives the drive spindle in which should then turn the tilt spindle,but the two are not connected...so the motor is spinning freely and not producing any angle of tilt ....
4th Feb 2014 10:27pm |
4th Feb 2014 11:13pm |
cheers mate.. but till i get the info of why the two spindle ain't making contact i wont be able to fix nought,hoping someone on here went through same problem and has the info...the whole system is back together all screwed back in,when the weather is right maybe summer time i will have another go figuring it out,not an urgent thing,the reach sensor works,like you said its just one of them nigli thing and i just wanted to get it fixed..cheers welshdragon.. |
4th Feb 2014 11:35pm |
