Home > Maintenance & Mods (L322) > Rubber door trim - Glue recommendation please.
T24RES
Anyone know of a fancy glue to stick the rubber. I've tried superglue, evostick contact adhesive so far, lasts a short while then lets go again.
Post #239629 4th Feb 2014 5:59pm
Did mine with soudal crystal clear acrylic sealer/adeshive.
Has held well for 3 months or so now. Did it with a few different things first none of which worked.
A good clean with some brake cleaner first. There is nothing that can't be fixed with a hammer😜😜
Post #239691 4th Feb 2014 8:25pm
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
try tiger bond....comes in various colours obviously black would be your colour of choice here going by the colour of the trim..you'll need a mastic gun as they mostly come in a tube,but once applied ain't nothing coming off..look them up on ebay... spelt " tiger bond " adhesive
regards steve
Post #240026 5th Feb 2014 6:59pm
T24RES
I'll have a look, thanks.
Tiger bond, I found this in a small tube.
Tiger seal comes in a mastic tube.
Which one is it? Ian
Post #240031 5th Feb 2014 7:19pm
greasemonkey1
tiger seal is the one you want..
Post #240183 5th Feb 2014 11:32pm
T24RES
Thumbs Up Ian
Post #240185 5th Feb 2014 11:34pm
